Old 10-07-2016, 12:58 PM
rantanplan rantanplan is offline
Default 888 Power Supply fails, clicking
Hi there
As a relict from my Mix system I still have a 888 I/O interface. I did not use it for years.
Lately I had the idea to use it as standalone A/D. Sadly it does not power up anymore. But there is some periodic clicking coming from where I think the PSU is seated.
Because this hardware is quite old, replacing the PSU is not really an option for me.
But maybe this is a known issue with a easy fix?
Kind regards,
Till
Old 10-07-2016, 11:59 PM
mrhappy1997 mrhappy1997 is offline
Default Re: 888 Power Supply fails, clicking
Nothing to add but interested in any solution that comes along as I have a few of those too.
Old 11-11-2016, 09:42 AM
bump
Old 12-26-2017, 07:58 PM
~rf~ ~rf~ is offline
Any help would be much appreciated. Even if it is confirmation of power supply failure.
Today I had the same situation happen on not one but 2 888 i/o interfaces. I don't use this old digi rig much anymore. when I powered on the 1st 888 it lit up briefly, went dark and then began to pulse like a metronome thru the outputs. I then powered the second and it seemed to be fine, so to use the system I disconnected the master slave cable and the 1st 888 cable and repowered the 2nd 888. It failed within seconds. These units worked fine just several months ago.
I have good power and these units are mostly disconnected from a/c when not in use to avoid potential damage from spikes or strikes.
HTML code is On
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
C|24 Power Supply Not working/Making Clicking Sounds!!!! drogan88 ICON & C|24 3 01-11-2008 07:29 PM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! snuffacation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-11-2004 03:03 PM
