Old 02-10-2016, 02:35 PM
Marsdy Marsdy is offline
Default Elastic Audio on distorted guitars
Ever tried Elastic Audio on distorted guitar? Tough job. EA finds it hard picking up warp markers unsurprisingly. The more distorted the guitar the worse it gets.
So.... When you record a mic'd distorted guitar, record a DI signal at the same time. Create an edit group of the the two and then enable Elastic Audio on both. EA will easily pick up the warp markers from the DI'd track and because they're edit grouped, the warp markers will be applied to the distorted track too.
Works a treat. Job's a good 'un as we say on this side of the pond.
P.S. The DI'd signal also comes in handy if you need to re-amp of course.
Dave Marsden
UK
Old 01-03-2017, 10:09 AM
bFooz bFooz is offline
Default Re: Elastic Audio on distorted guitars
Good trick.
Old 01-03-2017, 11:34 AM
amagras amagras is offline
Good idea, I might not use it on guitars but it can be useful in other situations. Thanks for sharing!
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Is there a way to make elastic audio less distorted? saltydeath 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-05-2011 02:43 PM
Elastic Audio on Guitars? lcphr3ak General Discussion 5 05-10-2011 01:44 PM
Elastic Audio on Multi-Miced Electric Guitars... PLEASE HELP!!! dglennjr Pro Tools TDM Systems (Mac) 13 05-09-2009 03:30 AM
Using 2 tracks when recording distorted guitars EVERGLEAM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 08-05-2005 09:32 PM
how do you record distorted guitars? badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-03-2003 01:43 AM
