Old 01-13-2016, 02:08 AM
Ljudit Ljudit is offline
Default Committing aux tracks renders a lot of silence
I'm working on a feature film and wanted to use the new commit track function to archive the project and make it safe to open in the future. I have consolidate clips unchecked. But when I commit an aux track Pro Tools renders audio every time there is audio on a track with a bus routed to the aux track even if nothing is sent trough the bus to the aux track. This makes Pro Tools take up al lot of disk space with just silence. I don't now if this is a bug, bad coding or a function that needs to be for some reason.
Pro Tools HD 2018.1 | HDX | HD OMNI | S3/Eucon 4.0.3 | Mac OSX 10.12.6 | Mac Pro 2013 | 64 GB RAM
Old 01-13-2016, 02:28 AM
Drew Mazurek's Avatar
Default Re: Committing aux tracks renders a lot of silence
Make a selection first.
Commit uses a level threshold to determine if there is signal present. Maybe you have some low level info that's causing it to think there's signal?
www.drewmazurek.com
Old 01-13-2016, 02:37 AM
Yeah I thought that too but I can assure you, there is nothing there. I tried to gain the clips as much as I could and zoom in the waveforms. Just silence.
Make a selection first didn't make any difference.
Old 01-13-2016, 03:59 AM
Dither? Analog modeling "noise"?
Sorry, forgot to add that once you make a selection, in the Commit dialog, choose Edit Selection and not Selected Tracks in the pulldown.
www.drewmazurek.com
Old 01-13-2016, 04:51 AM
Maybe. But as I said, I gained up the committed audio as much as possible and zoomed in the waveforms. There is no audio there.
Did that. No difference.
You can replicate this by creating a new project, import some audio on a new track, route a bus to a new aux track, commit the aux track. The bus volume is at infinity zero but still there will be a rendered clip on the aux track.
Old 01-13-2016, 05:08 AM
could not replicate, works fine here. The pulldown resets each time you do it, so you have to select Edit Selection each time FYI.
www.drewmazurek.com
Old 01-13-2016, 05:46 AM
I made a short video to show what happens https://www.dropbox.com/s/0vs6kwtmuv...0test.mp4?dl=0
Pro Tools 12.3 Crashes when exceed tracks while committing!!! thanos4 Pro Tools 12 9 11-30-2015 11:00 AM
Adding silence to audio tracks in the beginning... SpinningDisk Tips & Tricks 5 05-03-2010 07:16 AM
Committing Rewire tracks to audio files. logic7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-26-2006 09:30 AM
Adding silence to tracks JohnnyT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-21-2005 08:46 PM
strip silence treats multiple tracks as a group mike connelly Tips & Tricks 1 01-17-2002 07:11 AM
