Old 10-21-2015, 01:37 PM
oldmanpotter oldmanpotter is offline
Default D Command--no signal to phones
I've been using a D-Command for several years. Suddenly I can't get any signal out of the headphone jack. Ordinarily, in the monitor/cues section of the console, I select Phones, choose Main as the source, and hit the ON button and I'm able to hear outputs 1 and 5 (front Left and front Right when configured for the default D-Command surround format L x C x R Ls Rs LFE)
Another engineer has been using the system for a while. Is there a setting somewhere he could have changed? I can hear some low level clicks in the headphones when I change the volume, or change the source that feeds the phones, so it seems there is audio getting to the headphone jack. I also tested the switches using the TEST mode of the UTILITY section--they are all functioning well. I'm also seeing signal on the meters of outputs 1 and 5.
Thanks in advance for any help you can give.
It takes a big man to cry; it takes a bigger man to laugh at that man
Old 10-22-2015, 02:17 PM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: D Command--no signal to phones
could be that the headphone amp in the xMon (or D-Command) is broken.
If the headphone amp would be in the xMon, then you could "simply" borrow a unit from a friend ... if the amp is in the D-Command, then of course one would have to know where it is and how to get a diagram for testing what exactly is broken.
This is my idea to your problem
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 10-22-2015, 03:56 PM
Thanks Steff. Since I do hear some very low level audio coming from the headphone output, I don't think the headphone amp is dead. It seem more like the internal switching that connects the various sources to the headphone jack is not functioning. By the way, the audio I hear is not the source material, but what sounds like digital noise floor, and some very slights clicks as I adjust the output encoder knob.
P
Old 10-23-2015, 04:23 AM
P
Yes - thats what I meant more or less
The "internal switching" and amplifying etc. is all made *somewhere*.
If this process is done in xMon (as a part of the headphone circuit) then you could do a xMon replacement test.
If all this is done in the D-Dommand itself, you would have to borrow a D-Command ... or take your xMon to a friend who's running a D-Command and check it out there.
Cheers, STeff
Old 10-28-2015, 01:03 PM
Thanks STeff!
Old 02-20-2018, 01:27 AM
TopStudioMiami TopStudioMiami is offline
Thanks STeff!
Could you solve the problem? I have the same fault.
Old 02-20-2018, 04:29 AM
Jeezer Jeezer is offline
Yeah to me that does sound like a dead op-amp chip that feeds the phones (either inside Xmon or the main unit). Same happened recently in the Moog Sub37 synth even from new, and Moog had to replace some boards. The chip in question is usually quite cheap and easily fitted (if not SMT). I have a feeling it would be mounted in the main unit rather than xmon, as the main unit deals with the heaphone section taking from the 'main' source from Xmon.
Though it may well be on some mainboard and could be a tiny SMT chip, it's still do-able but tricky if so.
Of course, it could still be some weird setting or a dead button not making contact, or a dead relay etc
D-command problem with phones level not stable mtung ICON & C|24 24 12-02-2005 01:13 PM
Running phones w/002? RobN General Discussion 5 06-12-2005 10:11 PM
Using PT just with h'phones on a Laptop??? The Neophyte 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-20-2004 11:42 AM
:Phones::EditPack: multipro ProControl, Control|24, Command|8 0 08-25-2002 11:44 PM
