Let Pro Tools set system sample rate
Hi all,
Does anybody know if Pro Tools can be in charge of the system sample rate. The number of times I load a session to be told that "The current playback engine does not support a sample rate of ??kHz" so I then have to close Pro Tools, go into the M-Audio Control Panel change the sample rate to the required rate then reload Pro Tools. Surly Pro Tools can be set up so that it loads the required sample rate itself. I'm a PC user with Pro Tools 12, with an M-Audio Project Mix IO. Any advice would be greatly appreciated. Thank you |
Re: Let Pro Tools set system sample rate
You likely have Windows or another application using the interface at a different sample rate, and no Pro Tools cannot control how you have things set up--but hopefully you can.
And believe me, YOU should be in charge
I'm on a Mac, but found this for you on another thread that may help http://duc.avid.com/showthread.php?t=358268
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
The simplest fix is to just make sure that the audio interface you are using for PT is NOT set as the default audio device in the Windows control panel. Set your built in motherboard device as the default. Then you won't see this error come up anymore.
DC-Choppah's Project Studio: ASUS PRIME Z390-A / Intel i7 rackmount PC Windows 10 home 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle Tascam US-16x08 Interface 100% Analog real time monitoring 16x4 Yamaha 16 channel MG16XU Analog Monitor Mixer Yamaha MX-88 / Novation XiO keyboards Mackie 4-channel headphone amp Adam A8X monitors Blue / Shure, etc. microphones Estonia 6' 8" Parlor Grand Piano Yamaha Studio Drum kit https://www.dc-choppah.com/ |
Pro Tools could not set sample rate to specified value | Prabha | Pro Tools 11 | 5 | 09-08-2014 10:59 AM |
Pro Tools could not set sample rate to specified value | SixStringRockteer | Pro Tools 9 | 4 | 06-29-2013 05:24 PM |
Mbox 2 Sample Rate in Pro Tools 10 | bfleenor | Pro Tools 10 | 0 | 11-01-2011 10:55 AM |
Pro Tools LE Sample Rate Mismatch Nag | tcassel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-20-2007 12:51 PM |
Pro tools free sample rate | SoundWrangler | Digidesign Hardware & Software | 1 | 09-17-2002 12:34 AM |
