Old 01-28-2014, 01:35 PM
boxturtle boxturtle is offline
Default Manually uninstall 10.3.8 from Mavericks
Looking for help from anyone who has done this.
Thanks.
Old 01-28-2014, 01:42 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: Manually uninstall 10.3.8 from Mavericks
Load up the clone you did before you loaded PT 10.3.8. If you did not do one, I would do a clean re-install of Mavericks; do a clone of that system; then re-install PT 10 if needed.
Some have tried un-successfully to manually remove PT 10. Good luck.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 01-28-2014, 02:09 PM
Thanks, Doc. Are you running PT 10 on Mavericks with success?
Old 01-28-2014, 04:07 PM
Oliver M Oliver M is offline
Here is what to remove from PT 10 on Mavericks in order to uninstall PT 10:
Uninstall PT 10 manually (on OSX 10.9.x Mavericks)
In Mac HD/Library/Frameworks trash the following files:
AFnd.framework
CFnd.framework
DAE.framework
DFW.framework
DHS.framework
DigiPlatformSupport.framework
DigiStreamManager.framework
DirectIO.framework
DSI.framework
DSPManager.framework
DUI.framework
In Mac HD/Library trash the following files:
Application Support/Avid/Pro Tools
Application Support/Digidesign
In Mac HD/Applications trash the following files:
Avid/Pro Tools (you may want to keep your Plug-In Settings folder)
In Mac HD/System trash the following file:
Library/Extensions/DigiDal.kext
In ~/Library/Preferences trash the following files:
com.digidesign.ProTools.plist
DigiSetup.OSX
Pro Tools Prefs
There will be parts deleted that are used by PT 11 as well but they get re-installed once you launch PT 11.
Last edited by Oliver M; 02-28-2014 at 01:50 PM. Reason: There was one slash too many in one of the paths.
Old 01-28-2014, 04:19 PM
dr_daw's Avatar
No problem, I ran it on a test drive over the weekend. Sessions with Arturia Moog and 10 audio tracks 24/48 with no problems. Didn't run my waves plugs because I forgot to put them in the cloud. I really didn't see any benefits in Mavericks, so I will hang in Mountain Lion as that is super stable for me. I don't have 11 so no testing of that. IF you're not forced into Mavericks, I'd roll back to Mountain Lion and wait it out. Avid has expressed no interest yet of supporting 10, but I have no interest in supporting 11; that may change if I find more information to support that it's worth my while.
Rig
Old 01-28-2014, 05:10 PM
Roger that. Super thanks to you both for your replies.
Old 05-17-2014, 05:25 AM
PD-John PD-John is offline
AFnd.framework
CFnd.framework
DAE.framework
DFW.framework
DHS.framework
DirectIO.framework
DSI.framework
DUI.framework
DigiSetup.OSX
Pro Tools Prefs
Thanks so much for this! I installed Mavericks today, but I hadn't uninstalled PT10 yet... so your post was very helpful. PT11.1.3 up and running fine now on OS X 10.9.3.
Old 05-17-2014, 09:12 AM
YYR123's Avatar
YYR123 YYR123 is offline
AFnd.framework
CFnd.framework
DAE.framework
DFW.framework
DHS.framework
DirectIO.framework
DSI.framework
DUI.framework
DigiSetup.OSX
Pro Tools Prefs
Nice info Oliver
Daniel
Old 10-12-2014, 06:35 AM
doogzone doogzone is offline
I have PT 8 can't uninstall anymore from os mavericks
Can I apply those steps to remove PT 8 (seems like PT8 got same files)
thanks
Old 10-22-2014, 12:15 AM
Mark Dann Mark Dann is offline
The PT uninstaller WILL work if you log out and log back in as Root. Goggle that if you don't know how. And yes, it works.
Uninstalling Pro Toos 10 on Mavericks (manually) lucykrakow Pro Tools 10 5 06-23-2014 10:28 PM
How do I uninstall PT10? No 'Uninstall' option in Control Panel epu Windows 5 06-26-2012 06:25 AM
Deleting DAE folders manually PT8 scar97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-15-2009 09:32 PM
A way to manually input pan value? jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-09-2006 06:05 PM
Manually creating a tempo map? spicyitaliano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 11-18-2004 05:27 PM
