Old 01-01-2007, 06:56 AM
Alwyn Walker Alwyn Walker is offline
Default Re: Enuff Q: How about some tips!!!!
Here's one I sometimes use for sorting out an overly dynamic kick (or snare) drum performance:
(a bit obvious maybe)
if the quieter kicks still sound good enough to use...
1 - alt shift D to duplicate the kick track (keep the original)
on the new track:
2 - use strip silence (command u) or beat detective (command 8) to seperate all the kiks
3 - audiosuite normalize all the kicks at once (set to region by region)
4 - batch fade in and out (keep 'em shorter than strip silence's start buffer thingy)
5 - now you can blend this track with the original to balance the dynamics of the kik.
This is A LOT better than soundreplacing less than 100%, cause there's no possiblity of phasing or misaligned trigger points. Also, you can show the drummer it is still HIM playing it. well kinda... is it ever?
Alwyn
Komodo Studios
Northern Ireland
Protools HDcore G4 dual 1GHz (soon to G5 )
Old 06-10-2013, 09:03 AM
scrnplyr's Avatar
scrnplyr scrnplyr is offline
Default Re: Fixing an overly dynamic Kick or Snare track
Hey, thanks for laying it out in simple steps.
I'm gonna try this on my next session. I usually don't completely trust computers to do my janitorial work, but damn I'm tired of making the drummer sound good when I could be watching re-runs of Family Guy!
AJF
Now: MacPro Tower OS 10.8 - PT2018- MBox Pro - MACKIE preamp for monitoring only - mostly WAVES PIs - a couple of AKG/Shure Mics - MAudio Key49
Up Next: Mac Mini M2, PT 2023.9, Focusrite Solo - I love this set up! It's faster than I could have hoped for.
Then: ProTools 5-ish digi001 on a PC running Windows Millennium
BD (before digital)-from Tascam 8-track to Neve 64 - ran live audio for Club 88 in LA (Decline of Western Civilization) and Stage East in N Hollywood
"...this puts things into perspective...too much ****** perspective..." David St Hubbins and Nigel Tufnel standing over Elvis' grave.
Old 07-02-2013, 08:34 AM
daeron80 daeron80 is offline
First time I've ever heard of a good use for Normalize. Whodathunk? Good work.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 07-02-2014, 06:01 AM
Jenre Jenre is offline
I imagine this would have a similar effect to parallel compressing the kick? A lot easier on people's cpu resources though, I suppose!
Old 07-02-2014, 08:55 AM
Other options;
Insert Waves L1(or similar) limiter to push the louder hits down(so you can bring the overall track up)
Use a drum replacement plugin(Drumagog or similar) and replace with a sample and set a limited dynamic range(you could even use the original drum as the replacement sample by grabbing a single shot)
Old 07-02-2014, 09:33 AM
YYR123's Avatar
YYR123 YYR123 is offline
I know huh
Daniel
Old 07-02-2014, 09:34 AM
YYR123's Avatar
I thought i was the only one
Daniel
Old 07-26-2015, 04:10 PM
AhwatukeeComputerRepair AhwatukeeComputerRepair is offline
Have you tried Parallel compressing the kick? Or even separating where the kick does not hit has hard and just use a meter to clip gain each kick to the correct level.
Old 12-29-2016, 11:56 AM
bFooz bFooz is offline
I would put a "balancing" compressor as the first effect. This would have the attack set to -10ms (pre-attack 10 ms), release the longest possible, keeping the whole hit sound compressed, but being released right before the next hit. Threshold set right above the quietest hit, ratio depending on the aimed dynamic differences between hits.
What these settings do is they leave quiete hits as they are and when the louder hit comes, it get pushed down for the whole duration of the hit with no compressing artifacts.
convert kick and snare track to midi... monkey Pro Tools TDM Systems (Mac) 7 02-12-2014 08:05 AM
Strike: Unable to bleed kick & snare into HiHat track? StinkyStan Virtual Instruments 5 05-30-2009 09:21 AM
How to get the kick and snare velocity even? Tormentor MIDI 4 10-30-2004 05:07 PM
That Big Ol Kick and Snare!!! Opal Music General Discussion 5 01-23-2003 04:20 AM
converting kick and snare track to midi monkey MIDI 1 01-15-2003 11:18 AM
