Pro Tools 10 Asio Problems Windows 8
I recently had to downgrade from my MacBook Pro to a Dell Inspiron until I can get my Mac fixed. I tried installing the same pro tools that was on there to my Windows computer and I've been having problems. I've did a lil research on my problems and they have been getting resolved until I ran into this problem. When I press play the music plays but its skipping repeatedly and popping. I cant record like this.. Nor listen to a beat without it skipping. I've noticed at the bottom of my screen my Asio Driver Icon is flashing from a green play sign to a red and yellow error sign.. When I try to lower the buffer size it gets worse and the music plays in slow motion a little. And still glitches... I need help. .. Im on a clean computer with 4 GBs of ram. Pro Tools 10.3.2 Windows 8 Pro
Re: Pro Tools 10 Asio Problems Windows 8
Nowhere near enough info for anyone to help. Read this thread: Help us Help You - READ THIS Before Posting! and post a Sandra report, and what interface you are using. The Dell may not be compatible. Windows 8 is a toss up as Pro Tools isn't tested or approved on it(although some are having success). For playback, try setting the buffer to 1024.
My system info.
Inspiron 530S Windows 8 Pro Pentium Dual-Core CPU ES200 @ 2.50 GHz 4 GB Ram 64-Bit Operating System Im using Pro Tools 10.3.2 With a avid m box mini.. And when I put the buffer on 1024 It still glitches and skips when i push play |
Pro Tools 10.1.2 AND 10.2 ASIO Problems | Weiry | Windows | 8 | 05-28-2013 01:16 PM |
Pro tools 10 and latest 002R asio driver problems | scubadrum | Windows | 6 | 09-09-2012 02:17 PM |
Pro tools 9 ASIO problems | coltonb | Pro Tools 9 | 4 | 12-21-2010 10:21 AM |
ASIO Problems after installing Pro Tools LE 8? | Devils | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 47 | 01-20-2010 07:51 PM |
Asio driver problems with 002 Pro tools 7 with SP2 | inka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-03-2007 08:01 PM |
