Old 04-13-2012, 11:14 AM
LBC LBC is offline
Default PT10.1.2 no launch after update [solved]
Hallo,
After running the Pro Tools 10.1.2 Update, my application won´t start!!
Message;
The application has failed to start because it´s side-by-side configuration is
incorrect............
I´m running a swedish Win7 sp1 64bit. I have tested with two diffrent computers, the same problem.
What´s the problem, anyone??
LBC
Old 04-13-2012, 03:15 PM
sinukus sinukus is offline
Default Re: PT10.1.2 no launch after update!!!!!!!!!!
Does running vcredist_x86.EXE from http://www.microsoft.com/download/en...ng=en&id=26347
fix the problem?
Below Zero Beats on 92.7 FM San Francisco
Sundays 8pm - Midnight
http://belowzerobeats.com
Old 04-13-2012, 03:46 PM
LBC LBC is offline
You´re my man!!!!
Thanks Sinukus
Problem solved, This must be something that´s been missed in the patch,
Most DAW computers are not on Win update, so this file should have been included with the patch???
Thanks again,
LBC
BSOD after PT10 Upgrade (Solved) CookSier Pro Tools 10 1 01-28-2012 09:01 PM
Pro tools launch issue with 8.04 with 10.6.6 solved!!! ohyoshimi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-01-2011 08:38 PM
[Solved] Cannot launch Pro Tools 9 Kim G. Rasmussen Pro Tools 9 7 11-11-2010 05:14 PM
PTFree launch error/ Problem Solved Farmead Digidesign Hardware & Software 2 01-30-2002 04:06 AM
DAE errors on PTF launch-solved Dean Rolley Digidesign Hardware & Software 0 06-14-2001 12:21 AM
