Old 11-04-2011, 08:43 PM
soundeq soundeq is offline
Default Delay Comp problems again, Delay comp is RED but way below limits.
I have tried re-tried to open, even copied session over at 44.1k instead of 48k
For the life of me, I cannot get the red delay compensation light to go off... I have turned delay comp off and on, even turned it off in the mixer engine and on again... There is only 1200 samples of delay needed (and shown in session setup) Mixer engine is set to long...
Obviously something is screwy with delay comp in 9.0.5
Here's photo proof....
http://i1104.photobucket.com/albums/...laycomp1-1.jpg
Oh the usual 9.0.5 / OSX 10.6.7 / Trashed all prefs... plugs current.. Restart etc...
I could be wrong...
Old 11-05-2011, 12:26 AM
danander11 danander11 is offline
Default Re: Delay Comp problems again, Delay comp is RED but way below limits.
Try changing to 11 processors at 99%.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 11-05-2011, 12:29 AM
Tried 11 processors. Nope no dice...
I could be wrong...
Old 11-05-2011, 01:32 AM
crizdee's Avatar
crizdee crizdee is offline
Do you have any sends routed back to the same track? Like re generative delays etc? This causes the dly light to come on! Happens on my template for this reason
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-05-2011, 06:10 AM
stargazer stargazer is offline
Yes, Chris, it could be something like that.
Check your routings if you record your back mix via a bus etc.
Tip: Hover your mouse over the red delay indicator in the transport - you'll get info about the possible feedback loop.
Hakan
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 11-05-2011, 10:19 AM
midnightrambler midnightrambler is offline
I also got this when I had an aux track and had made the input inactive. It took me quite a while to figure out that's what it was.
Old 11-06-2011, 03:08 PM
Tripple checked my routing... can't find a feedback loop anywhere, or an un-assigned aux.
I could be wrong...
Old 11-06-2011, 03:16 PM
K Roche's Avatar
K Roche K Roche is offline
If you hover your curser over the delay box a little yellow window should appear that will tell you what and where the problem is if it's feedback loop or an inactive aux track etc.
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 11-06-2011, 03:42 PM
Got it... random feedback loop (fader wasn't up) on a hidden track... :-/
thanks for the rollover tip
I could be wrong...
Old 11-08-2011, 04:33 AM
Bushpig Bushpig is offline
Guys,
Thought about starting a separate thread, but decided to post here instead.
I've hit my first annoying snafu with PT10HD. My DLY light is permanently red because I use the standard "ping-pong" delay setup I've been using for years (all the way back to the old SSL and AMS delay routine). ie: DLY turns red because I have two mono aux's with a single long delay on each and send them back and forth between each other using pre fader send busses (gives me the fine control I need to set panning, feedback levels and filtering etc between each of the "pings" and "pongs" that I need).
PT10HD is reporting this to the delay compensation engine as an error when it most certainly is not. ie: when I put on (the annoying) tooltips and details, it correctly tells me that I have two channels feeding each other, but that's what I want and that NEVER used to post a red DLY light. I know my delay compensation situation is OK despite this, but now if and when I DO have a genuine compensation issue, I won't even know it because my residual attention will have retrained itself to say "the DLY light is ALWAYS red, no problem here, move along".
DTS. Any comment on why this was changed?? Can we please put it back the way it was or at least give us a pref for it. Something along the lines of "Report channel loops to delay compensation warning indicator -on/off"
Grrrrrrr!
Cheers.
Steve Bush
www.music180.com/pros/5887
Delay Comp Question blastula Pro Tools TDM Systems (Mac) 1 07-11-2013 08:35 AM
Delay Comp Red Matchless Gift Pro Tools 9 7 10-13-2011 06:28 AM
delay comp = red on aux strewnshank Pro Tools TDM Systems (Mac) 11 07-20-2010 02:42 AM
delay comp vs ATA therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-18-2009 06:58 AM
Delay Comp righton041 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-04-2004 09:45 PM
