BIG BUG: 9.0.5 (Lion) No preview when dragging Automation, Fades and regions
When I drag fades, region boundaries and automation I see no preview. Only the cursor moves and I have to guess what appears. Big Bug. Please fix or give a tipp how to fix.
Re: BIG BUG: 9.0.5 (Lion) No preview when dragging Automation, Fades and regions
This is really a mess to work with. It is barely not acceptable. Please do a quick fix. I´m sur that it is not a big problem.
9.0.5 + Lion = BETA!
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
"...give a tipp how to fix"
List your setup including graphic card (s) Clean install? 9.0.5 full, 10.7 or 10.7.1..... Hardware etc.... Vague = rumor |
This is no problem of my setup. I am no newbie. This is a problem with Pro Tools and Lion. 9.0.5 full + 10.7.1. With snow leopard everything worked fine.
Pro Tools 9.0.5 beta (cross grade from PT8LE) Mid 2011 i5 iMac 27" 12GB OS X 10.7.1 - Updated from 10.6.x - AMD Radeon HD 6770M |
UPDATE: This does not happen on NEW sessions created with PT 9.0.5! Only on older sessions created with PTLE (I think my co-producer uses v7 or 8).
We've been able to reproduce this and it seems to show up most often when using 2 monitors.
Is that the case with anyone (everyone) here? |
No, I am only using the built-in iMac display. Glad to hear you guys are on the case though!
And, just to be sure, you're on Lion and do not have any other monitors attached (even if you're not using them), correct?
No yellow outline when dragging regions/no breakpoint editing preview | djaikon | macOS | 8 | 11-22-2011 08:56 PM |
anyway to access Preview and Automation preview on PC or Edit | vudoo | ProControl, Control|24, Command|8 | 1 | 09-12-2009 06:49 AM |
PT not dragging automation when moving regions | diegogat | Pro Tools TDM Systems (Mac) | 1 | 07-27-2007 07:41 PM |
Losing volume automation when dragging regions. | Taddy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-27-2006 09:11 PM |
fades on muted regions render active fades?! yikes | clarpark | Pro Tools TDM Systems (Mac) | 11 | 02-08-2004 04:49 PM |
