Old 02-09-2003, 01:31 PM
el biciclista el biciclista is offline
Default Help: Suddenly Digidesign Control Panel ON bogs things down
I have:
-PowerMac G4 867, using OS 9.2.1
-ProTools HD (HD 1, 192 I/O)
-Waves Gold, McDSP plug-ins, Waves Masters
I have other applications on my Mac for occasional use, even thought I am using ProTools 90% of the time. Specifically, I have Microsoft Office 2001.
I have noticed that suddenly Excel is very slow. Before this, calculations were lightning fast. By much trial & error turning extensions on/off, I finally find that the problem is solved simply by switching the Digidesign Control Panel OFF. The problem occurs even with ProTools CLOSED. I have always left the Control Panel on in the past at all times...no problems with other applications.
The only things I have done recently that I can identify is:
-Updated Waves to version 3.6
-Updated McDSP plug-ins to latest versions.
Could the Waves update be causing this problem....even with ProTools OFF?
Yes, I can simply switch the Digidesign Control Panel OFF and restart the Mac whenever I want to use Excel. But I'd like to understand what caused the problem and hopefully find another solution.
Any suggestions?? [img]images/icons/confused.gif[/img]
Thanks!
Mike
Old 02-09-2003, 01:46 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: Help: Suddenly Digidesign Control Panel ON bogs things down
Try deleting the following:
System Folder/Preferences/Sound Preferences
Administrator
Old 02-09-2003, 02:02 PM
Digi Admin,
You got it!! Great.
NOW I remember that I did go to Sound Manager and switch the sound output from Internal to Digidesign. I have surround speakers with the 192 I/O as the only input (thru a volume controller). I wanted to listen to a transcribe program thru the surround system.
I guess I'll have to go to Sound Manager each time I want to do this, then reset to Internal.
Thanks SO much. I wouldn't want to tell you how many hours I have spent trying to solve this.
Thanks again, [img]images/icons/smile.gif[/img] [img]images/icons/smile.gif[/img]
Mike
Old 02-09-2003, 03:33 PM
Digidaw Digidaw is offline
Originally posted by el biciclista:
Digi Admin,
You got it!! Great.
Mike
<font size="2" face="Verdana, Arial">You should _seriously_ consider going OS9.2.2... works 100% here and has done since it was released.
Regards.
DigiDAW.
Old 02-09-2003, 06:50 PM
Will do.
Thanks,
Mike
Digidesign Control Panel...N/W on G3 LesPaul666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-05-2001 07:44 AM
Digidesign Control Panel probs.. Sound Works UK Pro Tools TDM Systems (Mac) 5 04-22-2001 02:18 PM
Digidesign Control Panel ... TCL Tips & Tricks 1 07-12-2000 08:25 AM
Digidesign Sound Control Panel Kenshiro Pro Tools TDM Systems (Mac) 4 07-07-2000 01:41 PM
digidesign control panel not working gaus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-07-2000 01:27 PM
