USB Midi Controller for 11R
I have been attempting to try and hook up a Line 6 Shortboard to control my Eleven Rack. Currently , I have Pro Tools configured to recieved Machine Code from the shortboard for play/record/ stop and it works correctly. But, I can not get any CC message to be received by any of the plug ins, like Xpand or Boom. I have also noticed that the 11 Rack windows has not midi learn functions so I am not even sure if I can control any of those functions without using a no-usb device that is plugged into the Eleven Rack.
Has anyone ever used a USB Midi device to control the 11r |
Re: USB Midi Controller for 11R
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
If you have a Mac, you might be able to use the IAC, or even just route it in your Audio MIDI Setup.
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM Pro Tools 10.0.0 Ableton Live 8.2.1 RME Fireface 800 Eleven Rack |
OK so I figured it out. I have been searching the documentation in Pro Tools (and the web) and really could not find anything clear on this. But watching the included video did talk a little about setting up a midi track in Pro Tools for using a keyboard to control some of the plug-ins like Boom. So I thought well maybe that is how I need to set it up, and of course that is how you set it up.
Other then seting the FBV active in midi -> input devices and enable machine control for transport options, no other settings where needed. So each session will need to have a midi track with the i/o in put set to the FBV and the output set to eleven rack. I then used the Line 6 FBV Control software to set up the device. I have two setups, one using MMC for the transport controls, and the other using CC's for control patch and bank changes, wah and volume. For bank changes i use the midi command program change with a value of 4 and increment/decrement. It works perfectly. Well you do need to recreate the midi track in each session and you need to have Pro Tools loaded and a session opened to use the controller, so obviously no standalone mode. But it will get me by for now until I decide to use the device live. To some that have een using Pro Tools (or any DAW) for a while this process might seem normal, but for a noobie not so much. Hope this helps. |
You might consider creating a template, and then you won't have to manually add and configure the track and i/o.
a.k.a. crazyForce |
That is my next setup, just need to figure it out I was trying to export the track as midi but I assume that is just for the data.
So thank you for the help, that will steer me in the right direction. After that I need to figure out how to punch in and out, probably simple for you, new to me. Regardless, I am having tons of fun with this device. I have a GSP that I have been using for a few years and I love it, but the recording interface of the 11r is killer (not to mention it sounds great!). It is too bad there isn't a practical use manual. It seams most of the manual just gives breif descriptions with no real examples. But I am getting there. Also, I tried setting the FBV up in Midi Studio but the results where not very good. I could set it up using the "external" for 11r control but it tends to cause a signal lose issue between Pro Tools and the 11r. Using the "Eleven Rack" has the output was a no go. |
MIDI Controller (Roland Juno D) not controlling Midi | Featherstone | Pro Tools 10 | 3 | 07-25-2013 05:59 PM |
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
Setting up a USB/Midi Controller while using a tascam audio/midi interface | disabledpro001 | macOS | 5 | 03-30-2012 07:06 AM |
Midi newb - USB Controller + Midi Keyboard @ same time. | Monty_python | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 11-26-2008 01:56 AM |
I can WRITE midi notes, but midi controller won't. | ::mitch:: | MIDI | 4 | 10-17-2002 03:29 PM |
