Old 11-16-2010, 04:33 AM
kirka.sainio kirka.sainio is offline
Default Write Automation to All Enabled Parameters in PT9 with mBox,
Hello,
Do You know if the shortcut to Write Automation to All Enabled Parameters (Command+Option+Forward Slash) is included in PT9 with MBox? It wasn't available in PT LE, only HD.
Thanks,
Kirka
Old 11-16-2010, 05:02 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Write Automation to All Enabled Parameters in PT9 with mBox,
Originally Posted by kirka.sainio View Post
Hello,
Thanks,
Kirka
If you have the complete production tool kit!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-16-2010, 05:16 AM
Chris
OK. CPTK is too expensive for just that function. I know that I can allways record automation on the fly, but do You know any better/faster workaroud for that shortcut.
Kirka
Old 11-16-2010, 09:19 AM
lexaudio lexaudio is offline
Write to all enabled worked on my PTLE 8 with DV Toolkit.
LEX
Old 11-16-2010, 11:52 AM
OK, it seems that Avid has made it a pro users only feature.
But do you know any other way I could tweak my automation parameters and then write it to a selected area?
Thanks,
Kirka
Old 02-23-2011, 09:46 PM
druck druck is offline
Thanks,
Kirka
You posted this question a few months back so you've probably already found a workaround, but you can always just use write mode. Make sure under Setup/Preferences/Mixing you have "After write pass, switch to" switched to off, then make a selection on the track you wish to automate. Now, make sure you only have "plug-in" highlighted in the automation window (Window/Automation or Apple+Numeric 4) and hit play with the track in write mode.
This will allow you to dial in your plugin parameters during loop playback (you have to make sure they are automation enabled in the plugin, of course) and once you get them set right you can let Pro Tools go through one more complete pass without touching any knobs. You'll basically have just done the same thing as "write to current enabled", it just takes longer and is dangerous if you forget you don't have "after write pass, switch to" not set to latch or touch.
Hope that makes sense!
Old 01-11-2013, 03:13 AM
Fabe1234 Fabe1234 is offline
Hey Druck!
Thanks a lot! This is exactly what is looking for! A very big help for me and my workflow.
Cheers!
[IMG] code is Off
Auro write to all enabled parameters - how with d control? murks ICON & C|24 6 03-31-2009 11:38 PM
"write to all enabled parameters" shortcut not working Eric L Pro Tools TDM Systems (Win) 3 05-05-2007 07:49 AM
EQIII automation bug using write to all enabled Matt Chan Pro Tools TDM Systems (Mac) 3 12-23-2005 02:33 PM
Write to all enabled parameters webstereo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-06-2005 10:39 AM
Write automation to all enabled parameters? MoviePhile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-25-2003 07:54 AM
