Old 10-28-2010, 05:23 AM
Tom Hartman Tom Hartman is offline
Default HD Native Delay Comp Question
Couple of dumb questions that I'm not clear on here...
Is the amount of delay comp on Native greater than on HD?
Having been using Logic for awhile, I don't even think about Delay Comp but it seems like in PT there is a lot of manual fiddling required, is Logic doing something different than PT?
Thanks
TH
Old 10-28-2010, 05:41 AM
Drew Mazurek's Avatar
Default Re: HD Native Delay Comp Question
It's the same, it has to be for session compatibility.
And I've never once "fiddled" with anything in regards to ADC in PTHD.
www.drewmazurek.com
Old 10-28-2010, 07:24 AM
I've never done a session that didn't exceed the DC ability to keep up...to avoid late vocals, etc, I've had to slip....never had to do that in Logic...
Old 10-28-2010, 08:09 AM
drenkrom drenkrom is offline
Logic (and most other serious DAWs) do things differently, indeed. They have unlimited automatic delay compensation, the operative word being "unlimited". Digi has chimed in in the distant past to say they really can't do more because of the TDM architecture. Same goes for offline bouncing and all its derivatives, such as track freeze.
Basically, it's a hack job. It's the best that could be done without changing the fundamentals. I've learned to work around it, but it's still the pebble in my otherwise-comfortable ProTools shoe. You have to keep an eye on that if you're used to a different DAW environment.
Old 10-28-2010, 08:47 AM
mattrussell mattrussell is offline
it's mesmerizing. i have both logic and PT and almost always use PT. there are some really cool built in tools in logic that i keep going to.
since i made the move to HD, i swear the lack of ADC is making my mixing life worse. i dealt with it when i was on LE and for whatever reason, it feels much worse in HD. i know LE has no ADC engine at all, so maybe i'm nuts. i had a system and it worked. i'm seriously considering tracking everything in PT and mixing in logic. i really hope the next major release of PT will address this. it's pitiful and i think we've all made it perfectly clear that we're sick of it.
make the move avid. i know that i'm certainly open to just about whatever it takes to make this work.
http://www.gainstructure.com
Old 10-28-2010, 09:13 AM
So it is the same in HD Native then....hmm another reason not to give up HD for native...
TH
Old 10-28-2010, 09:34 AM
ekuehnl's Avatar
ekuehnl ekuehnl is offline
ACI/ALP Moderator
TH
Yes, I believe the Short and Long settings are still 1023 and 4095.
Old 10-28-2010, 09:36 AM
pezking pezking is offline
The LACK of ADC? Do you mean that it is not long enough for you? Have you got it switched on?
I don't mean to sound condescending at all...
Old 10-28-2010, 09:50 AM
Fidelis Fidelis is offline
Hello Tom, that's strange. Are you using lots of RTAS on aux? I mix BIG sessions here and NEVER exceed the DC limit in PT.
Some rules:
First you should disable DC on the master track. Don't need that.
Second: As I record to disk (instead of bounce to disk) I also disable DC on my 2-buss aux if I have some RTAS plugin there.
Third: Avoid the following scenario: Send all drum tracks to an aux (drums buss). Insert and RTAS plugin on this buss. Make a send from Drum Buss to another aux (reverb for example) that also has a RTAS plugin there (ex a reverb like Lexicon). So in this case, I either DON'T put any RTAS plugins on my Drum Buss OR (in case I need the RTAS plugins) I use a TDM reverb for the drums (ex. TC's VSS3).
If you follow this rules is almost impossible to exceed this limit.
Oh, and use the LONG delay on playback engine.
Ricardo
http://www.ricardomosca.com
Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard
Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0
Old 10-28-2010, 10:25 AM
Some rules:
Ricardo
Thanks Ricardo, I am new to HD and dealing with this so will try all this, I have been careful to watch RTAS plugs on Auxes, but for some reason some channels still show up in red even without RTAS on them, gotta get the hang of all this. I'm using the short delay to save horsepower because I'm on a lowly HD1 for the moment, saving for HD 2
TH
PT HD|Native +Delay Comp midnightrambler macOS 1 08-29-2013 08:39 AM
PT 10.0.0 HD Native Automation Problem with Delay Comp Chris Trent macOS 5 01-07-2012 03:04 AM
Delay comp question KrisHeinold macOS 4 09-28-2011 05:27 PM
Delay Comp question Kourquie Pro Tools TDM Systems (Mac) 6 06-25-2009 07:20 PM
question about delay comp and UAD-1 rhythmtechnologies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-05-2009 10:23 AM
