Old 08-03-2010, 09:50 AM
GreenDC GreenDC is offline
Default C24- Phantom Power causes crackle and pops
Hi all, I'm having issues with my Control 24 interface- I get incessant crackles on several channels of the first bank of preamps when phantom power is engaged. When it is turned off, the signal is clean as a whistle. Even when there is no cable plugged into the input of the problem preamps, if the preamp is turned to mic, there's crackle. Another strange issue is that if I have an external preamp in the signal chain before the preamp on the C24, there is no crackle (via a patchbay). Any idea whats up with this? The second bank of 9-16 is fine, and this seems to manifest every summer, when it is more humid, and here in DC it gets super humid. Thanks
Old 10-16-2010, 11:06 AM
conrad787 conrad787 is offline
Default Re: C24- Phantom Power causes crackle and pops
Hello GreenDC,
I too live in the DC area (Bethesda, MD - www.blueroommusicstudio.com)
I don't have crackles with phantom power, but some WEIRD issues with phantom instead. For some reason, mic input #3 will NOT send phantom power out to a condenser mic. If I plug a dynamic into #3 it sounds great, and if I plug a condenser into 1, 2, or 4-8, it sounds great as well. Does anyone know why the C24 would decide not to send phantom out certain channels?
Thanks,
Conrad
Blue Room Productions
Old 10-20-2010, 09:35 AM
otlyer otlyer is offline
Am in dc too
Old 10-21-2010, 07:44 AM
Some ideas to consider:
For GreenDC, external preamps should come in via LINE inputs(which don't have phantom power). Maybe check your snakes(try swapping the 1-8 snake with the 9-16 snake and see if the problem moves).
For conrad787, check the snake and I bet you find a bad ground/pin 1 on your #3 line. A dynamic mic will work fine without pin 1, but phantom power needs pin 1 to complete the power connection(pin 1 carries the minus side of phantom DC voltage)
Old 10-21-2010, 06:08 PM
Fullsound Recording Fullsound Recording is offline
Or a bad rail feed in general at PSU - PSu connector- or jacks mount to PCB? Maybe oscillating Dc at PSU?
www.fullsoundrecording.com
Seattle Wa
I voted at www.deardigi.com
002R Faults + power harness + no phantom power DaveSB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2009 01:10 AM
recording with phantom power *and* without phantom power simultaneously SweetSoulSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-22-2008 07:40 PM
Crackle and Pops D-MACK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-29-2007 05:33 PM
Random pops, crackle, and clips. very annoying WizDoomBorn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-08-2005 07:33 AM
Guitar Crackle and Pops? Punx Tips & Tricks 3 04-07-2003 02:40 PM
