Old 07-27-2010, 05:21 AM
LungFish LungFish is offline
Red face Sibelius 6 midi files to into Protools problems
Hi everyone,
I have always been able to import midi files from sibelius 5 on a PC into protools 8 LE with success.
Recently I have upgraded to a MacPro 8 core and bought sibellius 6.
When I play the midi files ( imported for sib 6) with plugins the plugin settings wont stay put and always revert back to some weird default setting. eg I select play the piano plays using the midi track, I turn the piano down and when I stop the track the volume resets to where it was before I altered it.
I tried importing midi that I created on sibelius 5 a while ago and this problem did not occur so Im guessing it's something to do with the way I am exporting the midi files in sibelius 6 or the way protools is responding to sibelius 6 files but unfortunatley I have not been able to rectify the problem as of yet.
Any advice would be appreciated.
Thanks
Old 07-27-2010, 09:25 AM
DigiTechSupt's Avatar
Default Re: Sibelius 6 midi files to into Protools problems
It sounds as if there's MIDI volume data in the MIDI region. You should open up the Event Viewer and look for volume messages, then delete them.
Avid Audio Tech Support
Support FAQ
Old 07-28-2010, 12:36 AM
Talking Re: Sibelius 6 midi files to into Protools problems
Perfect it worked straight away no problems.
Thanks for that.
Cheers
Old 07-28-2010, 01:54 PM
Cool - glad it was an easy fix!
Support FAQ
Old 07-28-2010, 02:41 PM
strangeLoop strangeLoop is offline
When ever I import MIDI from Sibelius 6 into ProTools 8, I have to go thru each track and delete all of the MIDI volume and controller data.
I hope that at some point ProTools will be able to directly import a Sibelius session. Then you will have a choice if you don't want that data to come with the MIDI notes. Also with a direct import you would get tempo and marker information.
John Clavin - AKA: Old Horseface
Old 08-03-2010, 06:25 AM
dsmusicstore dsmusicstore is offline
Smile Re: Sibelius 6 midi files to into Protools problems
I agree with this answer it helped me out loads!!
Last edited by DigiTechSupt; 08-03-2010 at 10:29 AM. Reason: Commercial ads are not allowed.
Imported Sibelius MIDI Files in Pro Tools 10, not playing back Eric.Yeung Windows 2 06-07-2012 04:34 AM
Problems Reading Imported MIDI (Sibelius) janos Pro Tools 10 2 01-13-2012 02:30 PM
Problems with MIDI in 002R since I installed Sibelius 6.2 Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-04-2010 09:56 AM
Problems with MIDI I/O of 002R while running Sibelius 6.2 Chris7514 MIDI 0 12-03-2010 11:45 AM
Converting Vision files to ProTools or general midi files!!! Paata 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-17-2008 01:11 PM
