Only 2 channels on an Ultra....thanks
Hello and thanks in advance to anyone who attempts to help me. I have Protools 8 running on an Imac (Snow Leopard) with an Maudio Fast Track Ultra. My PT8 recognizes all 4 inputs on my ultra only occasionally. Generally speaking, the PT will only see inputs 1&2. It is as though I do not have the Ultra powered but I do. Clearly the power is working because I use the phantom power which is lit up and I do have signal at inputs 3&4. They are just not recognized by PT8. Is there any simple solution to my problem?
Thanks again, Ray |
Re: Only 2 channels on an Ultra....thanks
Sounds to me that you need to change your I/O settings. If you use 'Last settings used' when beginning a new project, it will carry the issue over to the new session. If you have already created paths for those inputs and outputs, it could be the Ultra. I am not fully familiar with that interface, but as interfaces go, they do the same job.
I'll bet you're right. It would not be the first time I have been challanged by the in/out processing of the Ultra. I will avoid the last setting option and see if I can resolve this....thanks Ray
Are you bus powering the FTU? If you are powering it by usb only, only 2 channels will show as there is not enough juice to run all 4 mic pres. Plug in the AC adapter and all 4 should be there.
J |
Actually I had the ac attached. BBennett was correct and all I had to do was change the i/o setting to "stereo mix" instead of "last used" when starting a new session and and I got all 8 channels backs. Thanks to all.
Ray |
Not enough ASIO output channels available.at least 2 channels are needed. | kudca | Getting Started | 1 | 05-26-2013 04:05 PM |
M-Audio Fast Track Ultra 8R channels | Evgenia | General Discussion | 0 | 01-31-2013 03:24 AM |
Regular Ultra wide -Ultra 3-enclosures the same? | elementsound | Storage Subsystems | 0 | 07-03-2004 01:43 AM |
MSI KT3 Ultra 2 | robbins876 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-24-2003 11:19 AM |
DUAL Ultra 320 w/Ultra Segate Drives | Seller | Pro Tools TDM Systems (Mac) | 0 | 07-07-2002 02:43 PM |
