Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 07-14-2010, 01:02 PM
RodWall RodWall is offline
Default Change Session tempo without affecting Midi Regions
Hi!
Well, I grabbed my Midi Keyboard and Xpand and recorded a few things, without click. Now, hearing what i recorded, i see that was about 80bpm, but the session is 120bpm. I would like to know, how can I change the entire Session Tempo to 80 bpm, without affecting the Midi Regions, because that's what's happening!
Thank you!
Old 07-14-2010, 06:02 PM
BBennett BBennett is offline
Default Re: Change Session tempo without affecting Midi Regions
Not 100% sure, but have you tried disabling the Instrument/MIDI tracks then changing the tempo?
Old 07-20-2010, 02:34 PM
No, I haven't. I will give it a try and then I will say something. Thanks!
Old 07-21-2010, 05:17 AM
clausiii's Avatar
clausiii clausiii is offline
set your midi tracks to sample based tracks instead of tick based. It´s a little metronome on each track in the edit window which you can change to a blue ball...
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 04-10-2018, 11:08 PM
rose2004gene rose2004gene is offline
love you! It works!
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
Need to Change tempo but without changing existing midi data tempo? Einsteinwannabe Pro Tools M-Powered (Mac) 2 09-18-2010 06:58 AM
Fades on Multiple Regions get Deleted after Tempo Change 25ghosts Pro Tools TDM Systems (Mac) 0 10-10-2007 02:28 PM
changing tempo in a session w/o affecting midi chon MIDI 0 07-01-2003 05:22 PM
change tempo w/o affecting MIDI Felix Tips & Tricks 6 03-16-2002 12:38 AM
