Old 05-11-2010, 06:24 AM
RiF RiF is offline
Default Keyboard shortcuts (like switching mix/edit windows) stop working
From time to time (more often recently) the usual keyboard shortcuts for switching the Mix and Edit window (and others) stop working mid-session. Probably due to some keyboard shortcut that I hit accidently. The only cure is to close PT and reload it (takes forever...). Any tips?
Old 05-11-2010, 06:40 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Keyboard shortcuts (like switching mix/edit windows) stop working
trashed databases yet?
that could work|help...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 05-11-2010, 09:21 PM
RiF RiF is offline
I trashed the DBs, let's see if it helps...
Old 08-31-2016, 06:33 AM
RiF RiF is offline
5 years later and still no solution (trashing the prefs did not help) :-(.
The shortcut for toggling the mix and edit window randomly (as it seems to me) stop working mid-session.
Is there anything that I can have accidently done that disables them?
Old 08-31-2016, 08:23 AM
Would help if you gave us some info on your system (as well as what exact PT version) as without that we can't begin to help.
Jack
QAPLA!
Old 08-31-2016, 11:34 AM
RiF RiF is offline
PT 12.5.2 Vanilla on Windows 7 PC. Core i5-750@4 GHz, 8 GB RAM, standard USB keyboard, nVidia GT 560Ti, M-Audio Profire 2626, 256 GB System-SSD, 1 TB Data/Audio HDD.
This problem exists for me since 2010 now, so from whatever PT version was current back then until now. My system (except for the VGA and the system SSD) has been the same since then, also.
Old 05-16-2017, 02:59 AM
RiF RiF is offline
It's 2017 now and the problem still exists...
PT 12.7.1 now, the rest of my computer is the same.
In the mid of pretty much each session, some keyboard shortcuts just stop working. The most annoying thing is the mix / edit window toggle shortcut.
Old 05-22-2017, 01:25 AM
sandeepqwert1 sandeepqwert1 is offline
Location: Flat no. 5, Rajvihar II, Near Piplani Petrol Pump, Raisen Road, Sonagiri, Bhopal,
keyboard shortcuts key is very impotent to consuming time with help to this shortcuts to increases our speed and also apply on the life stories
Old 05-23-2017, 02:05 PM
Jack
QAPLA!
keyboard focus on - switching mix/edit window chris.d macOS 4 07-21-2012 02:13 PM
Digi/Avid: Why did my custom key command shortcuts stop working with 8.03cs1 ilovemyssl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-15-2010 08:21 PM
Transport shortcuts on keypad stop working Sunzate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-01-2006 04:42 PM
How to edit the keyboard shortcuts in PT pianoman_78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-27-2005 12:16 AM
Keyboard Shortcuts for switching MIDI views? rlcowa@work2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-20-2003 09:16 AM
