DAE error -9507 was encountered
What is this and why, and whats a solution? Cause I can't record, I either get no audio recording, or I get a straight high frequency tone. HELP ASAP!!!
Re: DAE error -9507 was encountered
Start here, and give us all the details about you issue and your system.
I have a Sony VAIO CW Series. With Intel Core Duo 2 Processor and Windows 7 (64 bit) I use a M-Audio Profire 2626 with a combination of Pro Tools 8 M-Powered. 4 gb of DDR3 RAM. I have a RICO firewire port. I already tried to reinstall the drivers, and nothing has worked. But I believe I have found the solution.. Correct me if I'm wrong.
I have a RICO firewire port. I need a texas instrument firewire port for the most efficency. And the cause of the DAE error is the glitcches with the Win7 drivers for PT. And the cause of my tone frequency issue is the firewire port as I said. |
I solved the problem on my windows 7 starter by going to setup > Playback Engine and set the DAE Playback Buffer(disk buffer), Plug-In Streaming Buffer to Level 0 and the Cache size to minimum. In my case my netbook has limited resources like intel Atom and 1 gb of ram therefore this solved the problem, however you can increase the buffer and cache size if your hardware is powerful enough to accommodate it.
Thanks Serkan Sendur |
Ah the wonders of the "SANDRA report".
Not having TI fwire chipset does not (and "should not" btw) mean that IS the problem. Quote:
No it's not the TI firewire chipshet again.. I have the exact same problem but i use fast track ultra 8R.. any ideas???
dae error 9507 | voodoo087 | Pro Tools SE and Essential (Win) | 0 | 03-08-2012 08:13 PM |
DAE error 9507 and 9031??? | Jordan Marshall | Pro Tools SE and Essential (Win) | 6 | 08-31-2011 02:57 PM |
How to fix dae error 9507 | dippedingas | Pro Tools SE and Essential (Win) | 1 | 03-28-2011 12:36 PM |
error -9507 | luna0409 | Pro Tools M-Powered (Win) | 0 | 08-22-2010 04:27 PM |
DAE -9507 Was Encountered | asimmd | Pro Tools M-Powered (Win) | 2 | 12-22-2009 11:35 AM |
