Old 12-30-2008, 03:37 PM
T-Jac T-Jac is offline
Default dual monitors... edit window + mix window
first let me say...i'm new to the pc world. On a mac I had my PT setup so on one monitor it would display my edit window and the other a mix window....
now that i'm in the pc I got my edit window on one monitor, but when i open up the mix window i can't drag it to the other monitor. seems like i gotta stay within the PT MAIN window. Is there a way to float these windows or something... that's worked before for me using cubase...
i gotta have dual monitors and dual windows.. help please!!! thanx in advance.
Old 12-30-2008, 03:44 PM
wolfskin wolfskin is offline
Default Re: dual monitors... edit window + mix window
'Restore down' the main PT main window (so that it is not maximized on one screen) and drag across both monitors. Then resize the edit and mix windows within each monitor, per your preference.
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2
AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM
www.wolfskinrecords.com
www.voodoopilot.com
Old 12-30-2008, 03:46 PM
The Weed's Avatar
The Weed The Weed is offline
Then close Pro Tools using Alt + F4 and your Windows arrangement should be "saved".
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-30-2008, 05:18 PM
no way to float??
thanks for your help... i guess this will have to due!
Old 12-31-2008, 07:28 AM
sw rec sw rec is offline
Define "FLOAT." You can put stuff wherever you want it this way.
Old 12-31-2008, 02:54 PM
paulrgmusic paulrgmusic is offline
I would also recommend Skootch. It is a little app by Bob Nagy (former Digidesign programmer) that will automatically put windows wherever you want them. I trialled it but stopped using it as I had to downgrade to a single monitor setup. It is a fabulous little program and he only requests a small donation via paypal.
[email protected] is his email address. This is the only way to get the software - it's not in shops or on websites (as far as I am aware).
Happy New Year everyone!
Paul
Old 01-07-2009, 07:31 PM
ducada ducada is offline
Originally Posted by wolfskin View Post
'Restore down' the main PT window (so that it is not maximized on one screen) and drag across both monitors. Then resize the edit and mix windows within each monitor, per your preference.
Ok. I'm running Windows XP and Pro tools 8. I have a dual monitor set up and this suggestion did not work for me..Are there any other suggestions?
Old 01-07-2009, 07:39 PM
The Weed's Avatar
Do what was suggested, then close Pro Tools using Alt+F4. Your windows configurations should now be remembered. Or get Skootch, it's highly recommended by those who use it.
Cheers,
SonoBus
Old 01-07-2009, 09:17 PM
TOM@METRO's Avatar
We run 3 monitors doing exactly as described above with no problems.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 01-08-2009, 12:11 AM
Stiff Stiff is offline
I haven't used Skootch, but several people I know are very happy with it.
Daily news & reviews
www.ProToolerBlog.com
Dual Monitors window placement Ray Campbell Pro Tools TDM Systems (Win) 3 12-10-2011 04:38 AM
ShuttlePro+Dual Monitors+topped window PhilBuckle Pro Tools TDM Systems (Mac) 0 09-14-2006 06:08 AM
Sudden Problem with Mix Window with Dual Monitors 100grit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-31-2005 08:09 AM
Remembering window positions for dual monitors. Swaphappy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-23-2002 11:54 AM
how to place mix and edit window on 2 monitors usinare 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 01-03-2002 12:20 AM
