Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 06-28-2008, 12:50 PM
idledude idledude is offline
Default 5 second delay when i hit record and play!
hey guys!
im using pro tools m-powered 7.4 with mac 10.4.1 and Firewire 1814
i was recording yesterday and all of a sudden when i started to record, "play" and "record" button would blink about 4 times and then recording would start!
when i hit play on its own it playback start away
i have no idea what it is, the performance of the mac seems to be ok, nothing is running slow.
i changed some playback settings but it didnt make a difference
can you defrag a mac drive?!
and wheres the latest pro tools update? should i update the mac system? i havent in about a year id say.
where can i get cymbal samples for idrum?!
so many questions!
thanks guys
M
Old 06-29-2008, 12:02 AM
audiogeekzine audiogeekzine is offline
Default Re: 5 second delay when i hit record and play!
Try changing the max recording length to a smaller amount, you may have it set to use all available space. as soon as you hit record it creates the files using the max size. When you stop recording it gets shortened to the actual size of the data.
You didn't mention any system specs, so I'll take a wild guess and say you are recording to the system drive as well.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 06-29-2008, 01:06 AM
ericdano ericdano is offline
hey guys!
10.4.1? Really?
Yes. iDefrag, or Speedisk Tools, or TechTool, or.......there are a bunch of tools.
Um, probably Digidesign.com and under support? Just a wild guess.......
so many questions!
Many of which could have been answered via a quick google search or two.
Old 06-29-2008, 02:44 AM
audiogeekzine
i changed the max length from all avalible space to 10 mins in preferences and it made no difference!
1.83 Ghz Intel Core 2 Duo, 2 GB of Ram, 80GB HD with 50 GB remaining
could it be post roll?
i put on system using recording and the green lights barely flickered!
i have downloaded PT update and 1814 driver update, ill try those?
what else could it be?
thanks
M
Old 06-30-2008, 11:06 AM
bradch00 bradch00 is offline
You don't have the "2 Bar Countoff" selected in the transport window and the click track muted or inactive and configured for "record only", do you?
edit; chris110000100101001 mentioned the same thing...
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts The Muphin Man Pro Tools SE and Essential (Win) 8 09-10-2010 07:03 PM
Hitting Play or Record, blue stop button lights up... delay Monty_python 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-06-2009 11:33 AM
Delay When Record/Play Button Pressed kaoticjackal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-25-2009 01:42 PM
4 Second delay after I press record and play, help! silentknight206 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-04-2007 02:25 PM
Delay before play and record Obsidian Dragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 10-07-2005 12:56 PM
