Old 09-11-2007, 01:49 PM
A.J. A.J. is offline
Default Session stops opening while Activating Inserts
Hi All,
This is my first post here - I'm having trouble opening a specific session. My other sessions open up fine, but this one stops opening and freezes PT while "Restoring Tracks... activating inserts" on a specific track (the mono overhead track). I have to force quit PTLE and I don't remember what inserts are on that track.
I've tried trashing prefs, DAE prefs, etc. but it's still not opening. I'd rather not remix the tune. Any suggestions?
My set up is:
Digi 003 rack
PTLE 7.3.1 cs4
MAC PowerBook G4 17"1.67 GHz PowerPC 1.5GB Ram
OSX 10.4.9
80GB firewire drive
Please let me know if I've forgotten any pertinent info.
Thanks in advance,
A.J.
www.myspace.com/andrewjacobs
Old 09-11-2007, 03:22 PM
Slim Shady Slim Shady is offline
Default Re: Session stops opening while Activating Inserts
Try creating a new empty session and importing the session data from the one you're having problems with.
Old 09-12-2007, 06:41 AM
Thanks Slim. I tried that and the same thing happens. Freezes up at the same place.
Any other suggestions?
Best,
A.J.
Old 09-12-2007, 09:10 AM
DigiTechSupt's Avatar
You very likely have a corrupt or incompatible plug-in installed. You should remove all plug-ins from your plug-ins folder then either put them back one by one while launching Pro Tools each time or put them in by halves and, by process of elimination, determine which is the offending plug-in.
Avid Audio Tech Support
Support FAQ
Old 09-12-2007, 12:44 PM
Thanks, DigiTechSupt. That was it.
PT 9 spends ages on "activating inserts", when loading a session Talisker macOS 1 06-23-2012 04:52 AM
Session load stuck at "activating inserts" SoundtrackArcade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-25-2009 06:18 PM
Making Inserts Inactive on Session opening Sebopath 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-09-2006 10:26 AM
Activating hardware inserts,help! speedyk5 Pro Tools TDM Systems (Mac) 1 05-20-2002 08:13 AM
Freezes on Activating Inserts essay Pro Tools TDM Systems (Mac) 2 06-13-2001 05:23 AM
