Old 07-31-2007, 07:21 AM
Jae Hwan Kim Jae Hwan Kim is offline
Default Filing in D-Show Standalone.
Hi Sheldon,
I am just confused about "filing" in D-Show standalone.
At LOAD or SAVE panel in 'FILING'tab, a file name is shown in the bottom right.
But I can't see the file name from SHOWS list of LOAD and SAVE, because I've deleted
it before.
In this case,
How can I know which file is being worked with and where it will be saved at?
Why the deleted Show file name is shown in the bottom right?
Old 07-31-2007, 09:44 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: Filing in D-Show Standalone.
Hi Jae Hwan,
The file name shown in the bottom right corner of the Filing page indicates the most recently loaded show file. It's there to serve as a quick confidence check that you're indeed working from the correct starting point, as in "did I really load the headline act's show file after the opening band was finished...?"
Hope that clears things up.
Sheldon
Old 08-06-2007, 01:44 AM
Thanks Sheldon.
D-Show standalone install problem jwilkens VENUE Live Sound Systems 1 03-09-2012 09:11 AM
Pro Tools/D-Show standalone integration idea with D-Show show files/virt. soundcheck digidesigner VENUE Live Sound Systems 2 11-08-2011 02:52 PM
D-Show Standalone Software [email protected] VENUE Live Sound Systems 2 11-12-2010 03:31 AM
D-Show standalone editor 2.8 and 2.7 on same PC? milkyco VENUE Live Sound Systems 5 04-08-2010 02:19 AM
d-show standalone software for MAC muzishun VENUE Live Sound Systems 2 01-24-2007 08:44 PM
