Old 12-28-2006, 05:33 PM
Fred Cannons Fred Cannons is offline
Default Digidesign Expansion Chassis Problems
I am having terrible problems running my expansion chassis! Anybody out there having problems with same?
G5 Dual 2.7 Ghz Power PC with 2.5gb RAM running 10.4.8 OS
Core card, Accell card and 2 Process cards
After over night cool down system powers up fine and alll is good. Then after some time (too variable to mention) there will be some sort of error. ie: "lost communication with Sync i/o" or Pro Tools will decide to loop half a bar of music and will continue this even after quitting PT and shutting down the G5. Then on re-start I get message "Unable to communicate with hardware etc etc"
Anyone experiencing this?
I have tried 2 chassis and 2 ethernet cards (Digi) and 2 Cat 6 cables
We are all stumped here .......
Old 12-28-2006, 05:57 PM
ProTooler ProTooler is offline
Default Re: Digidesign Expansion Chassis Problems
Have/can you run digitest? What are the results?
Have a great day.....
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Mojave with 64 GB RAM
PT Ultimate (2019.10)
Motu 16a
C/24 Control Surface
Old 12-28-2006, 06:51 PM
Craig F Craig F is offline
what version are you running?
Thank you,
Craig
Old 12-28-2006, 07:56 PM
I am running PT 7.2 cs 2
Have not done Digi test. I have been in communication with Digi techs and they have not mentioned that. I may try that tomorrow.
thanks-Fred
Old 12-28-2006, 08:56 PM
Dutchmuzik Dutchmuzik is offline
Definitely run a Digitest, I am running a G5 Dual 2.7 myself with an HD|Expansion Chassis, no problems here.
Old 12-28-2006, 11:50 PM
dr sound's Avatar
dr sound dr sound is offline
Fred,
Go to 7.3 . It will solve your problems. I had similar problems with 7.2, but when I went to 7.3 and the problems with the chassis went away.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 12-29-2006, 09:19 AM
Really - interesting. That is an easy fix - if it works. I will try that today - thanks for the tip Doc.
Digidesign Expansion Chassis Philee Digidesign Hardware & Software 10 10-06-2010 11:15 AM
Digidesign PCIe expansion chassis problems derF Pro Tools TDM Systems (Mac) 1 02-23-2009 04:48 PM
Digidesign Expansion HD Chassis and PT8 help!!!!! akmusic Pro Tools TDM Systems (Mac) 10 01-10-2009 07:28 PM
Anyone using the Digidesign Expansion|HD chassis? MDog Pro Tools TDM Systems (Mac) 14 03-19-2007 08:58 PM
Digidesign Expansion|HD Expansion Chassis work ok? Will Russell Pro Tools TDM Systems (Mac) 8 05-25-2006 02:19 PM
