Sync 002 Rack to Da88
I have a Tascam DA88 with a Sy88 card install. I need to dump 16 DA88 tracks to my 002 Rack, 8 at a time. (16 track session only 8 ins on 002)what is the best solution?
Re: Sync 002 Rack to Da88
I use an external USB device (MOTU) and send it time code from the DA88's. Note that you have to have the DV Toolkit for it to truly resolve. You'll have to bounce 8 tracks at a time unless you can convert one of them to ADAT Lightpipe, then you can do em all at once. I'm thinking though that since the DA88's are stale enough, you could PROBABLY bounce the first 8, then the second 8, and line them up manually....
I do want to transfer 8 at a time and then sync the other 8 to the first 8 in Protools LE. A few years ago I sync'd a PC to the DA88s using MMC(Midi Machine Control)by just using a Midi cable and an adaptor cable that connected to my sound card's joystick port and was able to start the Da88 and the PC would chase it, but I can't find the setting and such. I would think the Digi 002 would connect in the same way with the Midi ports. but I have not been able to get the two to talk. Thanks for any help, RNRDAWG
Plenty of old threads about this (including THIS ONE). You should try a search...
da88 sync to digi 002 | dubelieve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-22-2004 12:21 AM |
HD to sync ADAT and DA88 | Haniel Trisna | Pro Tools TDM Systems (Mac) | 23 | 08-06-2002 09:03 PM |
Sync 3/4", DA88 & PT together | babyseal | Pro Tools TDM Systems (Mac) | 9 | 02-24-2001 02:11 PM |
sync dat or DA88? | anders | Post - Surround - Video | 2 | 12-21-1999 02:30 PM |
Sync DAT or DA88? | anders | Tips & Tricks | 3 | 12-21-1999 02:28 PM |
