Do these shortcuts exist?
I know some of these shortcuts exist, some I've seen and forgot and others I'm not sure. Any help would be appreciated. I apologize if this has been covered many times before:
1. Enabling/Disabling a track 2. Selecting more than one track (but not all), for instance selecting 1-8 sequentially (obviously without having to select them individually). 3. Create tracks for playlists. For example...I have several playlists of audio on one track, a simple way to move them all out to separate tracks? 4. Delete selected track. 5. Before I sat down to type this I know I had more I was curious about, but any help with the above would be great! Thanks! |
Re: Do these shortcuts exist?
1. press command-ctrl and click on the output field in the edit window or on the small waveform at the bottom of a channel in the mix window.
2. click on the first track name, then shift click on the last one. but I think it's only since 6.9.x 3. ?? 4. You can make one in the keyboard pane in the system preferences or use QuicKeys. JC |
Thanks JC.
Rats, I'm still on 6.7. |
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. | jessedtf | Pro Tools 10 | 6 | 10-24-2012 09:42 AM |
Can 7.x and 6.x co-exist? | 3over3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-23-2005 08:20 AM |
does this mic exist? | laaaakes5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-06-2005 09:20 PM |
if the 001 didn't exist.... | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 02-19-2003 07:25 PM |
there exist?????? | Cesarin | Tips & Tricks | 3 | 01-22-2003 01:33 AM |
