Old 10-25-2005, 04:36 PM
district district is offline
Default MIDI Input in PT with Rewire?
I am mental and didn't even realize there was a MIDI specific forum area and will repost this thread there
Is it possible to bring MIDI into a PT track when rewired with Reason or Live?
There is one reference to it in the answerbase but it is from 2003. Here it is:
How do I record automation from my Rewire application into Pro Tools?
In Pro Tools, enable Pro Tools virtual MIDI inputs (MIDI>Input Devices - make sure Pro Tools Input 1-4 are checked), then create a MIDI track and select one of the virtual MIDI inputs on the input tab, making sure to select the correct channel. Then in your Rewire application, route MIDI data into Pro Tools via the virtual MIDI input bus. You will then be able to record MIDI data, including automation, from your Rewire application.
Currently, only Abletons' Live supports the Pro Tools virtual MIDI inputs. If you are using Reason you will need to use a 3rd party virtual MIDI application. Pete Yandells' MIDI Patchbay works well and is available at:http://pete.yandell.com
Maybe it's an older PT thing but I don't see any virtual MIDI inputs to check in the Input Devices menu. Plus, the freeware they mention is Mac only I believe.
I realize that I can export/import the MIDI info but I would like to be able to tweak as I go instead of being locked in. Thanks for any help provided!
Rewire issue - Midi Input Problem trying to launch Reason bunderson Pro Tools M-Powered (Win) 28 12-27-2016 08:08 AM
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
New to MIDI. Input is quantizing. Input Quantize is disabled LiamSlack MIDI 0 03-25-2008 08:59 PM
USB input versus actual MIDI input seanhupe MIDI 3 12-23-2005 07:35 AM
REWIRE "MIDI input problem" milk_meat1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-09-2005 02:11 PM
