Old 06-24-2005, 09:09 AM
el biciclista el biciclista is offline
Default Dumb question: How do I create Bar/Beat Markers??
Pro Tools 5.3.1 on a G4 867 running OS 9.2.2, HD2 with 192 I/O and 192 Digital I/O.
I have worked with tempo events a lot, but have never had a need to use Bar/Beat Markers. I read the Reference Guide several times on "Dragging Bar/Beat markers", but I'm still not clear.
I need to manually insert the markers at beats, then drag them to match an existing audio region I already have which has varying tempo. This will match my MIDI tracks with the audio region.
I'm not clear on how you establish that the marker is a Bar/Beat Marker, rather than a Tempo Event. The Reference Guide explains how to insert a tempo event. The Reference Guide also explains how to edit a Bar/Beat Marker, but not how to initially establish it. It says:
"You can insert Bar/Beat Markers one at a time by setting an Edit insertion point (instead of making a selection) before using the Identify Beat Command."
How exactly how do I do this?
Thanks!
Old 06-24-2005, 10:05 AM
webby webby is offline
Default Re: Dumb question: How do I create Bar/Beat Markers??
Have a look at Beat detective, you can generate bar and beat markers with this tool, then conform your other audio to these bar/beat markers.......
Old 06-24-2005, 11:20 AM
FajitaTone FajitaTone is offline
click in the timeline where you want the mark. where the flashing cursor is becomes the "edit insertion point"
Ray Trujillo
Freelance Audio Engineer
Beat Markers Appearing As Elastic Audio Markers Fabdickson Pro Tools 9 1 03-06-2012 05:03 PM
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! Robbry Pro Tools M-Powered (Win) 0 02-24-2010 02:14 PM
what do grid lines do after beat detective bar-beat markers cc1 Pro Tools TDM Systems (Mac) 1 05-22-2007 09:34 AM
Beat Detective, Beat markers to Tempo Ruler?!? phobia Tips & Tricks 3 01-01-2007 01:31 PM
Can't create Markers in HD Bookerv12 Pro Tools TDM Systems (Mac) 2 05-18-2003 04:03 PM
