Old 03-19-2024, 10:08 AM
Marsdy Marsdy is offline
Default MIDI plugins don’t like VE Pro - skipped notes+latency
Delighted to see MIDI Plugins in Pro Tools.
However, I’m having an issue using them with VE Pro. I have a couple of hundred Instrument Tracks routed to VE Pro in my template session. For each track, MIDI is routed to an individual VI (or an individual MIDI channel of an instrument) within VE Pro. The audio input of the Instrument Track is routed from an individual output of VE Pro.
If I insert a MIDI plugin on one of these Instrument Tracks, it doesn’t work unfortunately, at least not here! MIDI doesn’t pass through to VE Pro, even when the MIDI plugin is bypassed.
As a workaround, I’ve created a new Instrument Track and inserted a MIDI plugin on that. Then on the VE Pro Instrument Track, I’ve set its input to the MIDI Chain output from the new Instrument Track. This works if both MIDI tracks are record enabled but…. The latency is terrible and I’m getting a lot of random missing notes when using say EON-ARP. It’s unusable unfortunately.
So a bit disappointing! Is this a limitation of the new MIDI Plugin architecture, a bug or am I doing something wrong?
And regarding MIDI Plugins - to forum mods, would a separate AAX plugin in forum be a good idea? Also, can we have a page on the Avid site that lists available third party AAX MIDI plugins like there is for audio plugins?
Dave Marsden
UK
Old 03-19-2024, 06:30 PM
skylar_battles skylar_battles is offline
Default Re: MIDI plugins don’t like VE Pro - skipped notes+latency
I believe it's just a limitation of the new system unfortunately. If you use an "individual targets" as the MIDI output of a track with MIDI FX, the track will make no sound. At least in this test I just did with Riffer going into Xpand!2...
This thread may be helpful, if you haven't seen it: https://duc.avid.com/showthread.php?t=427895
Quoting myself from that thread in case it is helpful:
1. Virtual instrument must be after MIDI FX
2. To monitor the data through another instrument or print it, you need to set up an additional MIDI or instrument track and set the input to the chain output of the track's data you'd like to use. No way to print the data offline unfortunately.
3. Also "not all virtual instrument plugins support passing the midi chain data" so I could only assume at the present moment this only works for the newest versions of Avid plugins
Regarding the last point though, I could only imagine the MIDI plugins are also incompatible with almost all virtual instruments currently offered since feature is brand new, so that probably adds to your issues as well.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 03-20-2024, 12:39 AM
Thanks skylar.
Your point two is essentially what I’ve tried but I’m getting terrible latency and a lot of missing notes. Perhaps it’s because the Instrument Tracks I’m using for VE Pro don’t actually have a VI instantiated, I’m using them to send MIDI to and return audio from VE Pro.
One major limitation of the way MIDI plugins have been implemented is that you can’t actually use them on MIDI tracks!
Dave Marsden
UK
Old 03-20-2024, 06:08 AM
Ignoring my issue with VE Pro, I’m getting note dropouts recording the MIDI Chain output of an Instrument Track to another Instrument Track.
Dave Marsden
UK
HTML code is On
Midi notes deleting when editing and writing in notes SeventhSounding MIDI 5 01-14-2018 02:34 AM
Stop MIDI notes from overwriting other MIDI Notes? tjs5200 Virtual Instruments 4 06-16-2017 04:01 PM
MOJO Troubles - Skipped Frames at Video Start etwilliamson macOS 0 03-15-2012 03:55 PM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
001 skipped track problem skippy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-23-2002 07:45 PM
