#5581
Re: i7 Builds - Specs and Results
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#5582
Yep - I was psyched. However, enable the Ethernet port and I'm having to use 64 or 128 sample buffers .....
All four blue 192 I/O s are cranking right along :)
________________________ www.PlethoraTone.com PlethoraTone Studio Video Tour At PlethoraTone: Mac Mini M1, Avid Carbon, PSP, Waves Mercury, UAD, Kush, Slate Digital, PA, Melodyne, Antares, Audioease, SoundToys |
#5583
Some of the new Intel Ethernet chips let you adjust the filtering of network
interrupts so the processor is interrupted on different schedules. Under the advanced section of the device manager driver tabs for the controller. Might help.
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra |
#5584
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#5585
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#5586
I know this is a windows based forum but I just built a brand new Hackintosh with the ga-z87x-ud7-th mobo and i7 4770 K processor. If you guys are interested I can post some testing results. I'm using it as my mixing station at home. PT11HD with an Apollo Quad. Runs like a champ.
#5587
question on the Apollo, are you using Thunderbolt?
#5588
Computer Case: Silverstone Tek GD08B w/ Rack Mounts Mobo: Gigabyte GA-Z87X-UD7 TH Socket 1150 Power Supply: CORSAIR HX Series HX750 750W RAM: Crucial Ballistix Tactical Low Profile 32GB Kit (8GBx4) DDR3-1600 CPU: Intel Core i7-4770K 3.5 (Turbo Clocked to 3.9) Graphics Cards: Mobo HDMI and EVGA GeForce GTX760 SuperClocked Boot Drive (OSX 10.9.2): SanDisk Extreme 240 GB Media Drive: Seagate Barracuda 2 TB HDD CPU Fan: Noctua NH-L12 Low-profile Case Fans: 6x60mm Noctua NF-A6x25, 2x120mm Noctua NF-S12A PWM Pro Tools Rig Pro Tools HD 11.1.2 Avid Artist Control w/Eucon 3.1 Apollo Quad UAD 7.5 (FIREWIRE 800) Notes I just built this machine. So far everything is working flawlessly however I have not had a chance to try the thunderbolt ports on the board yet. It's a very powerful machine but only a quad core so I'll see what kind of power it has with the D-Verb benchmark. Can't wait to push it to its limits. Here is a link to my spreadsheet of parts and links to the Hackintosh setup instructions: LINK Pics Testing Cable Management (pretty hard to do in this case) Drive Bay Inserted Racked up and running Desk Setup |
#5589
As per our conversation earlier, Eyevanovich told me the fans are quiet enough to be eclipsed by mechanical hard drive noise. I think this is one of the most important things to note here, especially for a rack mounted build.
If you have the time, I'd be interested in seeing the readouts of CPU-Z and/or Core Temp to note the operating temperature of this thing during idle, Pro Tools operation, and IntelBurnTest or FurMark at full load after 5 minutes or more. With that case arrangement, CPU, and cooler... It would be expected that full load temps do not exceed 72º C. If they do during FurMark, I would be inclined to blame the 760. I don't know the efficiency of those ACX coolers offhand, but I imagine it's far from perfect.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#5590
The temps run hotter than I expected them to but I will need to do more benchmark tests to see what's going on. Idle temps usually sit in the 38-45ºC depending on the ambient temp. When under load from PT it runs in the 50s. When I ran the prime95 test I hit temps of 95ºC which kind of freaked me out. I may need to go back and re-apply my thermal paste on the CPU fan. It's my first build so I'm not sure I did it correctly.
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
