Old 03-14-2018, 01:53 PM
mhender mhender is offline
Default PT 2018 windows position multi monitor issue
I did a quick search and am not finding this. I use two video monitors in my setup and like to have the edit window and mix window on separate monitors. Since installing 2018.3, every time I reopen a session, the mix and edit windows end up on one monitor (mix behind the edit). I move the mix window to the other monitor and resave. Next time I open it's messed up again.... This never used to be a problem. Any help?
Old 03-14-2018, 02:07 PM
Panacci Panacci is offline
Default Re: PT 2018 windows position multi monitor issue
That has been happening to me when I was on 12.8.3, 2018.1 and on to the latest version. Drives me nuts
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com
Old 03-14-2018, 02:29 PM
I had it for awhile in 2108.1 but it seems like the position got saved with the session at some point, usually after second time opening the sessions and rebuilding the window layout. Now it 2018.3, it never works. Drives me nuts too.....
Old 03-14-2018, 02:34 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Working fine on Win 7. I stretched the "desktop"(gray box both windows are located in) to include both monitors, place edit in right monitor. Saves automatically. I have had to redo when I trashed preferences but otherwise stays put. There are existing threads about Mac monitor issues to check tho
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 03-14-2018, 02:48 PM
No issues here with 3 screens
Old 03-14-2018, 03:11 PM
TOM@METRO's Avatar
Nor here.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-14-2018, 04:30 PM
BScout BScout is offline
No issues here. You might want to mention what operating system. Windowing/window position has a lot to do with how operating systems map them.
Old 03-14-2018, 06:02 PM
PMF Media PMF Media is offline
not happening here either, maybe try changing the monitor setting in Mission Control to "Displays have seperate spaces" (tick the check box).
The Issue I'm having is that when I open a session that has open Audiosuite plugs present, a lot of them display a "grey" window rather than any controls, once I grab the window and move it, everything suddenly pops back to the way it should be, interestingly, it mainly the stock plugs that do this.
Old 03-14-2018, 07:40 PM
laki laki is offline
Hi Mhender,
Not sure if you are on Windows or Mac.
If you're on a Mac try going to System Preferences -> Dock -> Prefer Tabs When Opening Documents, Set this to "Manually".
I had the same issue as you but the windows were Tabbed behind each other. This fixed it.
Old 03-14-2018, 08:15 PM
treason treason is offline
This may help here
T-
Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3
DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO
Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc
Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc
Microphones: Telefunken, Neumann, Shure, AKG
Mac OS Sierra doesn´t restore window position on Dual Monitor System tonwurm General Discussion 10 12-03-2020 02:46 PM
multi-monitor bug? Windows-configurations always fail Sir Hannes Getting Started 0 03-02-2018 04:50 AM
Changing the tempo issue in 2018.1 RichrdC Pro Tools 2018 2 02-23-2018 06:33 PM
Waves issue with 2018 and Win 10 albee1952 Pro Tools 2018 4 02-09-2018 12:50 AM
Multi Monitor and windows Eric Heil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2002 09:50 PM
