Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 09-09-2017, 03:04 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Default Mac OS Sierra doesn´t restore window position on Dual Monitor System
Since I upgraded my Mac Pro to Sierra 10.12.6 there´s an issue with restoring window positions, primarily in Finder but also in some apps.
If I open f.e. a folder in Finder and move the window to the second monitor, after closing and reopening it, it opens always on the first monitor. Until now (on Mavericks f.e.) windows have always opened exactly on that screen where they have been closed before.
Maybe someone can give me an idea how to fix this issue. Thanks in advance.
MP 5,1 12core 3.46ghz 96GB
PT Ultimate HDX, Logic, DP, VEPro
MacBook Mainstage
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 09-16-2017, 08:57 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Mac OS Sierra doesn´t restore window position on Dual Monitor System
There's a way to do it using Mission Control which I discovered recently having the same issue. Basically you set up these "virtual" desktops and then you can right click on the app in the menu bar and set it to open on the monitor you want. You should Google it...
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
FocusritePro 40 (2)
TCE Studio Konnekt 48
Rascal Audio Tonebuss 24
Slate Digital VRS8
Gigabyte GA-Z170-HD3P
i7 6700K 4.1 GHz
32GB DDR4
macOS 10.15.7
UAD-2 Octo Core PCIe
Pro Tools HD 2022.10
Old 09-17-2017, 07:33 AM
tonwurm's Avatar
thanks for your reply Chris
But I´m not sure if we are talking about the same issue
only for clearness: I double click a folder in Finder and move the window to the second monitor. Then I close the window and re-open it. Instead it opens exactly on the last position (on the second monitor) it opens on the first monitor.
Before upgrading to Sierra I never had such an issue. I started the mac in Safe-Mode (disabling any extensions), but this issue remains.
I created a new user-account and there this issue doesn't´t occur ... strange.
I didn´t install sierra from the ground up (clean install) - instead I upgraded from Mavericks, maybe there´s something left from the older system that causes it
MacBook Mainstage
Old 09-17-2017, 11:06 AM
cwsand's Avatar
I'm not positive, but it seems like for me if I select Finder on whichever screen - that screen is is now the default for opening folders or accessing any open program's menu.
Help Us Help You
Chris
FocusritePro 40 (2)
Slate Digital VRS8
i7 6700K 4.1 GHz
32GB DDR4
macOS 10.15.7
Old 09-18-2017, 02:01 AM
tonwurm's Avatar
okay ... that seems to be something different
MacBook Mainstage
Old 11-05-2017, 06:50 AM
tonwurm's Avatar
I have to add that it wasn´t an issue occuring on a dual monitor system only. the issue was that the Finder didn´t store information like Finder-window size, position and view (f.e. column or list view)
I´ve found the culprit: after deleting all "com.apple.dock...." - preferences in User/Library/Preferences all finder folder windows occur in size / position / view as they have been closed before
wondering what these preferences had to do with this issue ... but it works ;-)
MacBook Mainstage
Old 03-04-2018, 11:26 AM
treason treason is offline
I too have had this issue since migrating from ElCap to High Sierra (same issue in Sierra - really anything post ElCap). It's been driving me nuts, and I finally found the cause and solution, if anyone else comes across this issue.
I use Spaces in macOS (6 of them) on my Pro Tools HDX machine, and have (for years) assigned applications to specific desktops (that way they open in the assigned space regardless of where they were launched from). In a Pro Tools specific instance, this is accomplished by right clicking the Pro Tools on the dock, selecting Options: Assign To: Desktop 1
THIS IS THE PROBLEM
If you do not assign an application to a specific Desktop, your windows (plugins, sends, mixer, etc) open where you last placed them.
To be pedantic - do not assign Pro Tools to a specific window if you use Spaces and your windows will restore to the last known location.
Hope this helps someone
T-
Waterstreet Studio Main: MacPro 2012 (12C@3.46GHz), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3
DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO
Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc
Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc
Microphones: Telefunken, Neumann, Shure, AKG
Old 02-20-2019, 03:30 PM
iggydolby iggydolby is offline
That's not true.... All sessions created with Protools HD 10 open perfectly with the Mixer screen on the Left monitor and edit screen on the Right monitor. Once I saved them and update let's say a plugin setting etc with ProTools Ultimate HDX they break and the window settings is never corrected again. Mixer and Edit open one on top of each on the right monitor no matter what I do or even saving new "Windows Configuration" I'm on Sierra also.
I've created a new session and still the same problem.
Old 12-02-2020, 11:09 AM
ivomarkovic ivomarkovic is offline
THIS IS THE PROBLEM
Thank you, Thank you, Thank you! I was looking for this for the last three months...
Old 12-02-2020, 03:17 PM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
For any one else trying this and looking for the "Assign to..." option in Dock; I'm pretty shure it went away at some point. At least, it doesn't show here on 10.15.7.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini M1, 16GB RAM. 512GBinternal(3000MB/s),2TB(1300MB/s),2TB(350MB/s)
MacOS 11.6.8. PT 2020.12.1 (Reinstatement on hold for M3 macs and AS native PT)
Topping D50 DAC, Dynaudio BM6p, Artist Mix, SSL UC1, EuControl on iPad.
Relink window doesn't remember position? poly915 Pro Tools TDM Systems (Mac) 2 10-18-2010 02:11 PM
doesn't the system usage window show 2 cpu-bars? der daniel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-06-2007 07:48 PM
Mix window gone on dual monitor Jason Kardong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-20-2007 07:41 PM
PT 7.0 doesn't keep the edit window 's position sssoundsss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-17-2005 04:05 AM
PCI in the System Monitor Window Pulses... a2zproductions Pro Tools TDM Systems (Win) 5 09-05-2005 12:56 PM
