Old 11-28-2017, 12:21 AM
SigFriedChicken's Avatar
SigFriedChicken SigFriedChicken is offline
Default MIDI notes still there after separating and deleting part of clip
I have a long MIDI track. When I separate it, a couple of minutes into the track, and then delete a large potion of it, I find that ALL of the MIDI notes are still there, just floating in space, completely outside of the clip.
I understand if there is an overlapping note, or two, but I don't understand why there are 20 bars worth of floating notes lying around after deleting a portion of a clip. Is there a way to delete the MIDI notes when you delete a clip? I know that I can go through and manually select them with the mouse, but then there is the issue of any leftover automation/pedal stuff.
It is quite rare that I would actually want leftover MIDI notes. If I wanted them, I would have deleted them, right?
Old 11-28-2017, 12:33 AM
EdwardWilliam's Avatar
EdwardWilliam EdwardWilliam is offline
Default Re: MIDI notes still there after separating and deleting part of clip
Similar thing happened to me just this evening. I selected the middle of a long midi clip, and deleted. The clip outlines disappeared, but the midi notes remained. After several tries I ended up deleting all of the remaining midi in the track after selecting the whole track. Doesn’t make sense.
Edward
midnightrambler midnightrambler is online now
Yeah it’s a bug. See this and other related threads mentioned within http://duc.avid.com/showthread.php?t=394955
Old 11-28-2017, 08:10 AM
daeron80 daeron80 is offline
Yep. Super annoying.
David J. Finnamore
Old 11-28-2017, 08:32 AM
Ideascale bug report submitted. Please let me know if anything in the bug report needs to be corrected or amended.
http://protools.ideascale.com/a/idea-v2/293501
David J. Finnamore
Old 11-28-2017, 06:07 PM
ronwasserman's Avatar
ronwasserman ronwasserman is offline
Same here. New bug (in my case) with 12.8.2. Did not have it on prior versions of PT.
Ron Wasserman
http://www.ronw.com
http://www.imdb.me/ronwasserman
http://www.fishertheband.com
Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version.
Old 11-28-2017, 08:06 PM
ZEUSS ZEUSS is offline
This has been the case for years! Its comical at this point with some of these bugs.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 11-28-2017, 10:03 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
For years? I've never seen this. Could it be a combination of factors that causes this? Or could it be a Mac-only issue? Whatever it is though, it's completely unacceptable. I don't understand why Avid finds it so difficult to get very basic stuff right.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 11-29-2017, 02:27 AM
It’s v frustrating I agree. Seems like every update has at least one “WTF?!!” *facepalm* moment in terms of new and/or reactivated bugs.
Old 11-29-2017, 10:50 AM
Windows, too. At least in this version.
Been around for years, but nobody bothered to submit a bug report? I did tons of MIDI work on new and old files in 9.0.3, 12.4, 12.7, each variant of 12.8. It didn't occur for me until 12.8.2. Maybe it was much more rare before.
David J. Finnamore
midi regions and deleting notes Shatzer Pro Tools M-Powered (Win) 22 10-25-2011 01:26 AM
Separating MIDI Notes in Relative Grid Mode filosofem MIDI 0 03-13-2009 03:22 PM
Deleting hidden midi notes jonah day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-25-2006 10:54 AM
Deleting MIDI double notes... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-17-2006 07:07 AM
Deleting/Copy MIDI notes is not deleting/copying MIDI sustain? Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2002 12:29 AM
