Old 11-14-2005, 05:13 PM
scuzzytim scuzzytim is offline
Default THE UNOFFICIAL \"DAVE C\" TEST RESULT THREAD
Okay, I thought it would be useful for people to start a fresh thread for anyone wanting to post their results for the Dave C test.
Heres my results:
Track count: 26
Computer: G5 iMac 1.8
Ram: 1.5 gig
OS: Tiger 10.4.3
Pro Tools Ver: 6.9.2
Hardware: MBox 1
Recording to a Lacie FW drive
Old 11-14-2005, 05:34 PM
dub3000 dub3000 is offline
Default Re: THE UNOFFICIAL \"DAVE C\" TEST RESULT THREAD
is there some kind of DaveC official template or homepage or something to test this with?
cheers
--dan http://remaincalm.org
Old 11-14-2005, 06:05 PM
David Penick David Penick is offline
Okay, here are my results:
Track count: 32 audio, 127 Aux*
Computer: G5 Dual 2.5
RAM: 8 GB
OS: Tiger 10.4.2
PT LE 7
Hardware: Digi 002
Recording to a Maxtor 7200 second internal drive
*please note: my CPU meter never went into the red; instead, I got a dialog box after trying to add one more aux (to 128) track, that I had exceeded the track limit. Also, after I had added 100 Aux tracks, my sixty seconds of audio was no longer audible.
Mac Mini M1 2020
Mac Sonoma
Pro Tools2024
Pro Tools Carbon
Old 11-14-2005, 08:32 PM
Very impressive, but I'm not sure I understand that last line - what do you mean , not audible?
Quad 2.5 G5, 4.5G RAM
Old 11-14-2005, 08:43 PM
Shan's Avatar
Shan Shan is offline
...*please note: my CPU meter never went into the red; instead, I got a dialog box after trying to add one more aux (to 128) track, that I had exceeded the track limit. Also, after I had added 100 Aux tracks, my sixty seconds of audio was no longer audible.
Your last line makes me wonder if you are doing the Davec test correctly. Your recorded audio will be nothing but a flat line and never audilbe.
Also, once you reach the 128 aux limit you can start using the new instrument track which is basically an aux track. the only problem is that we only have 32 of them.
There was a PC user that reached the 128 aux limit so he just started to add the instrument track to continue on. And if anyone is curious, it was with single Athlon X2 4400+ CPU.
What kind of results are we going to get with quads etc?? Wow!!!
That is a pretty impressive Davec result you have. Kudos to Digi for really making the dual core and multi cpu systems smooooooooooooooooke.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 11-14-2005, 08:46 PM
mgbasinski mgbasinski is offline
OK, Heres my results (Whoops, I realized these results are for a buffer size set to 512, not 1024... will redo and repost):
Track count: 31
Computer: G5 iMac 2.1
Ram: 1.5 gig
OS: Tiger 10.4.3
Pro Tools Ver: 6.9.2cs4
Hardware: MBox 1
Recording to an external OWC Mercury Elite Pro FW 400 drive
Note - first time I tried 31 tracks, I got a message that the disk IO couldn't handle it, but then 30 tracks worked, and then I tried 31 again and that worked (so that is close to the edge). 32 tracks definitely gets "holding off CPU"
iMac G5 2.1Hz /1.5 GB Ram
OS X 10.4.10
MBox/PT LE 7.4
Reason 3.0.4
MOTU 828
Logic Express 8.0.0
Garage Band 4.1
Old 11-14-2005, 11:57 PM
Matt82au Matt82au is offline
Track count: 30
Ram: 1.0 gig
OS: Tiger 10.4.3
Hardware: MBox 1
Recording to internal 250gb drive
Hoping PT7 will smash that even better!
Matt Perrott
Sound Designer and Engineer
Sydney, Australia
Old 11-15-2005, 02:42 AM
marty martin marty martin is offline
Track Count: 22
Computer: 15" "Power"book 1.5
RAM: 1.5Gb
OS: 10.4.3
ProTools Version: 7
Hardware: MBox1
This was recorded to my fairly well stuffed internal drive.
Roll on the new dual core intel Powerbooks in January!
Studio: Mac Pro Trash Can 2.7 Ghz, 32Gb RAM, Sonett xMac Pro Server, HDX 22.12, S6 M10 24 Fader, Rednet 5,1 and 4
Live: MBP 16" M1 Max i7 32Gb RAM,
Old 11-15-2005, 05:32 AM
EDurney EDurney is offline
Please guys!! post those davec scores on your Powerbooks!!...there´s a lot of us that need to Know!!
Pro Tools 10 / Duet 2 - Eleven Rack - Mbox 2 pro
MacBook Pro 2.2ghz Quad Core/ 8gb RAM/ 750HD
Pro Tools 9 HD / 192io / C24
Mac Pro Quad 2.66 / 8Gb Ram
Old 11-15-2005, 08:03 AM
CME CME is offline
24 at 1024 buffer on my Mini w/specs below.
At any lower buffer my CPU maxed out. With this setting it was my HD that couldn't keep up. Refressh rate didn't suffer terribly either. Considering it's nowhere near bleeding edge like the new dual core CPU's and quad core Mac I thought it did fairly well. Even if I'm 136+ tracks behind. I can't wait to see some quad core scores. If I start saving now I'll probably get enough saved up for the "New G6" Power Mac in 2007.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
The Official Unofficial Windows 7 Thread Benoni 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 776 08-24-2014 04:41 PM
The unofficial PTLE bottom-feeder thread! M.Brane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 07-18-2006 06:07 PM
unofficial "Problems with PT7" thread nikki-k Pro Tools TDM Systems (Win) 68 05-02-2006 01:00 PM
---unofficial BTD report only thread--- nikki-k 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 59 12-02-2003 04:29 PM
