  #21
Old 02-26-2014, 04:49 PM
TweedyBird TweedyBird is offline
Default Re: Track Presets in Pro Tools 10
I must be missing something. Everything works as advertised, I guess, but I don't see when I would use this rather than just create a new session using the template. If I click on New Track and select this, every track from my template comes into my session (so if my session already has a Drum track, and my template has a drum track, I now have 2 Drum tracks).
TweedyBird
TweedyBird
MacBook Pro OS X 10.9.1 w/ 16 GB RAM
Audio Interface: Focusrite Scarlett 2i/4
ProTools 10 Vers 10.3.8
  #22
Old 03-30-2014, 10:30 AM
Dave Modisette's Avatar
Dave Modisette Dave Modisette is offline
Well this is just too FRICKIN' cool. I thought I had lost Track Templates forever and I was forced to build massive multitrack setups.
A bit of confusion with the directories in Windows. In my case, there was a folder in Libraries>Documents>My Documents>Pro Tools. That's where I had to create my Track Presets folder and continue on from their.
Anyway, I know what I'll be doing this afternoon.
Dave Modisette
www.gatortraks.com
  #23
Old 03-30-2014, 11:12 AM
YYR123's Avatar
YYR123 YYR123 is offline
Dave what's up man - I bought the session strings from you!!!
I really want track presets but avid managed / not the work around
Daniel
  #24
Old 03-30-2014, 12:15 PM
TweedyBird
What about if someone brings a session to you and asks you to record/add to it? I saved track presets for drums(with all AUX tracks, bus compression and plugins, some of which are inactive for tracking due to latency, and a drum master VCA), a preset for 2-mic vocal recording(including reverb and the audio tracks grouped), another for 3-mic vocals. I have a preset for talkback, with the auto-ducking all preset. Another for acoustic recording(with 2 mics, grouped, plus aux track with reverb).
Last week I had a client bring 12 sessions started elsewhere to add vocals to. I created a preset with the 2 audio tracks(for tube and FET), vocal reverb, and talkback setup(total of 6 tracks). Opened each session and added all in a single step Sure I have a session template with everything, but I also have track presets for most things that I may need. If you can't think of a need, maybe you're not thinking it thru enough
  #25
Old 05-02-2014, 02:01 AM
frederic Bacquet frederic Bacquet is offline
Hey,
Is there someone who knows how to make it work with PT11 and windows 7. I use that trick on 10.3.8 and I missed it on my 11.
No procontrol driver + impossibility to use that... hard time !!!
  #26
Old 05-03-2014, 04:05 AM
Originally Posted by frederic Bacquet View Post
Hey,
As found by a simple Google search see posts 8 and onwards in this thread: http://duc.avid.com/showthread.php?t=338989
There's also this video on YouTube: http://www.youtube.com/watch?v=CLdZCWzx1KM
Can't help on the ProControl driver though other than to say you might want to check into Ideascale for a thread on that.
Jack
QAPLA!
  #27
Old 05-03-2014, 08:37 AM
YYR123's Avatar
What irks me is why doesn't avid just roll this functionality into PT - officially that is
Daniel
  #28
Old 05-04-2014, 02:23 AM
Hey little music mind...
I knew that videos.. but it only works with PT10.
Forums are full of little people like you.
I won't give thousands of links with answers like yours.
Everything is on forums yet and I don't need someone like you to know that.
Happy little sunday in your happy little life of happy little winner...
  #29
Old 05-04-2014, 03:44 AM
I'll ignore the snark but if you truly read the thread I linked to you'll see where the person that asked about using it in PT11 came back in post 13 and said that it worked for him as outlined by Oliver M.
Have you really tried what's outlined in the video? Same hack works in both PT10 and PT11; it's just knowing where to save the track presets to in PT11. In Windows I believe there's a folder tree coming off the My Documents folder that has a bunch of Avid stuff there and that's where you create (if it isn't there already) a Track Presets folder. I know the Mac version of PT11 automatically creates a folder of that name.
Jack
QAPLA!
  #30
Old 05-04-2014, 07:09 AM
Hey again,
As I told befor, I knew your "links".
So... do you think I tryed it before to post on that forum???
For your information, it doesn't work with protools 11 on pc. If you look at that video you will see that the subfolder is created in C/ x86 folders (32 bits) : PT11 is in programmes folder (64bits). That's why !!!!
So, if someone knows how to make it works for PT 11 in windows 7, it will be really helpful.
One other solution should be that for any reason, it doesn't work for MY computer.
Track Presets Kenny Gioia Tips & Tricks 30 01-31-2014 04:33 PM
Track presets in 11? albee1952 Pro Tools 11 2 06-24-2013 04:37 PM
Track Presets!!! albee1952 Pro Tools 10 8 12-29-2012 08:13 PM
Track/"Channel Strip" Presets DO exist in Pro Tools, apparently... PTPhillip Pro Tools 10 97 10-20-2012 01:03 AM
Track presets in PT??? dgkenney Pro Tools TDM Systems (Win) 3 12-22-2009 10:03 AM
