Old 08-24-2016, 04:05 AM
midnightrambler midnightrambler is offline
Default MIDI drum editor
Surely, surely there has to be an easier way of editing a MIDI drum part than siphoning through this lot...it's giving me a headache just looking at it.
http://duc.avid.com/attachment.php?a...1&d=1472036678
Isn't it about time we had some sort of MIDI drum editor?
Old 08-24-2016, 04:17 AM
Default Re: MIDI drum editor
Assignable colours for each drum would at least be a start. I did this all manually of course.
http://duc.avid.com/attachment.php?a...1&d=1472037419
Old 08-24-2016, 10:32 AM
Shan's Avatar
Shan Shan is offline
The best "workaround" I've used in PT is by using individual tracks with Single Note View and Clip Grouping in the main Edit window:
Track Folders would make the above "workaround" a little more ergonomic, but...
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 08-24-2016, 11:28 AM
That actually looks quite tidy - thanks Shane, I'll try giving that a whirl.
Old 08-25-2016, 09:49 AM
Carl Kolchak Carl Kolchak is offline
Usually what I do, is to capture the performance on a single MIDI track, and then from the Events menu, use the option to split by note, and place on individual tracks.
Then you just have the tracks display as single note, as previously described, and you've pretty much automatically got your drum grid.
So with a drum VI, I just draw in a single note for every individual key that the VI hosts a drum sound on (at Bar 1 / Beat 1, on a single MIDI track), and then do the split by notes function - and that's the beginnings of the template for that particular VI for import in to future sessions.
Obviously, the original MIDI track then gets deleted / muted.
Old 08-25-2016, 01:00 PM
john1192 john1192 is offline
hey Carl, does this work on Instrument Tracks as well ?? or just Midi .. not in front of it right now .. thx john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 08-26-2016, 01:09 PM
Shan's Avatar
It applies to both.
Shane
Old 08-26-2016, 02:48 PM
deanrichard deanrichard is offline
Being able to map notes to names (Kick, snare, etc.) helps even more. At least one other product offers that capability.
Old 08-27-2016, 03:39 AM
Yeah - triggering Superior Drummer with a pad or similar can result in eg the hihat part being spread all over the keyboard, which is pretty cumbersome to edit. It would be nice to have the ability to have the "hat" track on one line, with maybe a number or note or something embedded in that track to denote which sample was being triggered....? Strike uses lines per drum (much like an edit page in Cubase on a 1990s Atari) but there doesn't seem to be any neat way of creating slightly more sample-complex patterns within each line. Maybe I'm missing something ...
Old 08-27-2016, 08:07 AM
take77 take77 is offline
Additionally, if you'd like to zoom in on a particular selection, you can use the shortcut Ctrl+Start+ ] (Windows) or Command+Control+] (Mac).
Just remember to turn off the green MIDI speaker icon before lassoing a row of drum notes!
It can then be turned back on when entering new notes.
Is there a shortcut that toggles the green speaker icon?
MIDI Editor and MIDI Event Editor keyboard commands broken 12.4 HD Marsdy Pro Tools 12 5 01-31-2016 05:01 AM
Articulation with drum tracks in midi editor willl3 Pro Tools 10 1 02-23-2014 11:23 AM
Using Pro Tools Midi Editor for BFD2 drum mapping Qrackaduck Virtual Instruments 4 10-15-2009 08:53 AM
Any simple Midi Drum editor for PT7 available? mrsusan Tips & Tricks 1 11-25-2006 08:03 AM
drum editor xda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-31-2005 03:49 PM
