Old 05-29-2006, 02:44 PM
chal7ds chal7ds is offline
Default recommended duplicates on drums?
Hey All,
I'm still kinda newbie to PT and i was wondering what the industry standard or recommendation
is on doubling up tracks for your drum track? should you only have two going? three? (i'm talking in context for a rock song i guess..just a standard metal or rock beat...)
And how about guitars? i've been doing 3 mono tracks (so two extra on top of the original) is this a good practice? i've been doing 3 on the bass too...
just wonderin what everyone else methods are...
any suggestions greatly appreciated...
Old 05-29-2006, 04:02 PM
mkosacek mkosacek is offline
Default Re: recommended duplicates on drums?
I don't usually double drum tracks, but often bus them to an effect (reverb, compressor, limiter, etc) then mix that with the original.
Mike
Pro Tools 2022.9
UAD Apollo 16 (v10.1)
Dell XPS 8940 (i5-11400)
Win10
www.studiodrumtracks.com
www.doubledogrecording.com
Old 05-29-2006, 04:21 PM
AlexLakis AlexLakis is offline
One.
One.
One.
One.
Old 05-29-2006, 06:50 PM
are you guys joking? how do these professional bands sound so thick and sonic then? cuz i've recorded with 'one' on each..and it sounds like a little toy band playing in a garage. got to at least have double i'd think... ?!? unless you're just mic'ing them really well..
Old 05-29-2006, 07:00 PM
TheLP TheLP is offline
It really depends on the song and the sound you're trying to get.
Bass - I always only use one bass track. To me, there is really no point in doubling the bass track (unless you want it to be louder and give off a bigger vibe, in which case you can duplicate it, and pan each track).
Guitar - To get a bigger sound (in choruses with distortion and what not) try duplicating the same guitar part, and nudging one of the tracks a 64th note triplet over. This should give you that bigger sound.
Drums - Unless you're trying to make intricate parts with drum machines, you generally do not (at least I don't) duplicate drum tracks. If you want them to be louder, you can duplicate the track, and pan it to taste.
[TheLP]
spkguitar's Avatar
Give that man a prize.
Mixing them properly also helps...
(as does great sounding drums in the first place)
Old 05-29-2006, 09:19 PM
what about initial levels? Should they go up just before they hit the red level? or should they be halfway? or should they be just popping up a little bit? what's the practice goin' around on this? (for a rock track)
Old 05-29-2006, 10:57 PM
Shan's Avatar
Shan Shan is offline
Educate yourself here.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 05-29-2006, 11:07 PM
Shan's Avatar
...recommendation
Sometimes layered samples are added to the original kit. Parallel compression. A pretty big subject here depending what you're after.
Double tracked, Quadruple tracked, Multiple amps mic'd up. Tons of things can be done here. Really depends on what you're after. This one is another big subject.
One. But sometimes it's common to take a D.I. signal and a mic signal from a bass amp.
Shane
Old 05-30-2006, 07:38 AM
Naagzh Naagzh is offline
The "thick" sound you refer to might also be the judicious use of reverbs and delays. The Charles Dye Hard Disk Life series is very enlightening.
As for drums, parallel compression is used to give that beefiness to rock drums, while preserving the transients of the drum tracks. Also, it's not uncommon to have two reverbs, one for snare and one for toms (maybe a third for cymbals). But perhaps it helps the most to have a suitible room to record them in, especially if you've tracked room or ambient mics.
For guitars, the thickness could be two or more amps blended together, or it could be the guitarist playing the part twice, or both. The doubling creates a chorus effect (more than one "voice" of the same instrument). The subtle differences between tracks give the impression of a "bigger" sound. This can also be done by duplicating the original and nudging it (as per TheLP suggestion). It also helps to have reverbs and delays here, too, and a little of these goes a long way.
Use an EQ to scoop out some of the mud (around 350 Hz) from some tracks (start with snare and bass drum), and see if that alleviates your "garage band" problem. Sometimes a distorted guitar can benefit from a small cut at around 800 Hz, but be careful: lots of character in a guitar track lies in its midrange.
Watch for phasing! Getting two tracks to cooperate together requires that they be in phase. When two tracks are out of phase, you'll notice a loss of stereo field (if two tracks are panned wide, they'll get more narrow) and a loss in the low frequencies. Use the free 1-band EQ which has a phase invert button on it to check it out.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
How do I remedy duplicates in DigiBrowser? EricWillhelm Pro Tools 9 0 11-21-2010 11:42 AM
Slow audio duplicates? Dracula Tips & Tricks 2 11-14-2004 09:52 AM
Duplicates in Audiosuite menu jnorman16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-07-2004 02:48 PM
Recommended mics for drums??? crs117 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 10-18-2003 09:14 PM
Recommended Softsynth for drums.... Sean Malone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-09-2003 04:53 PM
