  #271
Old 11-21-2016, 08:58 AM
tberty's Avatar
tberty tberty is offline
Default Re: Track Input Monitoring 10.3.9 HD broken ?
Originally Posted by hivestudios View Post
Input monitoring is indeed broken in 10.3.9 Sometimes it works, usually it doesn't. It's most flakey when the input of the track you're trying to record to is set to a bus. So it's a real pain when you're trying to bounce down some processed tracks.
I'm using Mavericks, but as soon as I managed to downgrade to 10.3.8, it worked flawlessly, so clearly something broke between the two versions.
I also had the error of the Pro Tools logo just flashing for a second before disappearing after trying to uninstall 10.3.9 and then install 10.3.8. So I followed these instructions very carefully (they're halfway down the page):
http://duc.avid.com/showthread.php?t=350337
You should note that in order to delete some of these files, you have to "show hidden files":
http://ianlunn.co.uk/articles/quickl...s-x-mavericks/
Also, in the instructions above, there is a small error:
com.digidesign.ProTools.plist
DigiSetup.OSX
Pro Tools Prefs
Are in ~/username/Library/Preferences, NOT ~/Library/Preferences
I don't know what happened but the hidden files don't show after using those commands.
  #272
Old 11-22-2016, 07:33 PM
tberty's Avatar
DigiSetup.OSX
Pro Tools Prefs
It doesn't work
Track Input monitoring!? realizment macOS 9 11-04-2013 01:51 AM
Monitoring input and track during playback simonyeah Post - Surround - Video 5 09-24-2012 03:07 PM
track input monitoring vin7 Pro Tools 10 6 08-28-2012 07:08 PM
Pro Tools Track Input Monitoring??? MLH Studios Inc. Pro Tools 10 13 03-13-2012 11:03 PM
Single track Input Monitoring?? sylviesongs macOS 1 09-19-2011 01:41 PM
