Re: Please check these specs.
Why the 6031's? I have yet to have a 6031 error (knock on wood) I would like to know in case I start getting them.
This is one reason why I ordered my computer with an ATI card. The other is that I like ATI more. They seem more hardcore and I would even suggest they have better written software as well. I had a computer where I did a lot of audio for post production work (Win XP Pro). The computer had both Avid and PT HD2 on it and we often went back and forth between Avid and PT while working on projects. We must have burned 3-4 NVidia cards before finally getting a 70 dollar ATI. The computer has never had a glitch since then. Why did we get all those NVidia's? That's what was 'approved' on the Avid site. As to my post above and not getting any 6031's, I also have ATI on my current computer. GD |
Please just search "6031" in this forum, you will see and know much |
Nonetheless, at quick glance you could probably get it going but it's difficult to say 100% without an exact motherboard spec. The best thing to post us is the motherboard spec and of course a full Sandra report once you have it in hand. Wipe the C drive clean as these prebuilt systems are full of junkware and cause a lot of headaches trying to get them to run with PT. Dual boot with a fresh install of XP and W7 64. Go online and get the drivers for each component directly from each manufacturers website and make sure you grab the drivers only. Dont grab beta drivers. Avoid grabbing the drivers that are packaged with other apps. Dont use the drivers on the CD/DVD that comes with it as they are older ones and almost always packaged with useless software/junkware apps that get installed unknown to the user. Find out the current BIOS for the board and then check the BIOS number on the board itself once you get it. It might need to be updated. Grab Acronis True Image, if I recall you might already have it. It will save you days of troubleshooting down the road. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Shane
#16
I realize this is an HD forum, I do find most serious errors are not specific to version, except for Hardware errors. I could not say with any knowledge of the subject, but, I would imagine the DAE engine and base code for all 3 versions is the same. Just how they interact with hardware being different. I could be wrong. But I gotta say, between you and a few other people I see here a lot have very knowledgeable answers which helps a lot. I just don't like to see posts that assume you will never be able to use a certain configuration. As Tom states a lot, if you are running a studio have a stable version running XP, sure. But I think Digi needs us guinea Pigs to figure out what the problems are.
This is not a rant, I'm just letting you know why I posted that, because I have had problems (white noise) but no errors. Thanks for you time. |
#17
Shane, Thanks for your comments and for actually commenting on my original question and looking over the specs. As to the processors and the HP Z800 I was trying to stay with a system that Digi has approved. On the i7 comparison to the Xeon, I thought this was pretty informative: http://communities.intel.com/thread/...955B.node5COMS I will let you know what the motherboard is once I get the computer. Thanks again GD |
#18
Are your HD cards PCI or PCIe? Shane
#19
" Are your HD cards PCI or PCIe? "
They're both PCIe GD |
#20
Congrat's on the new rig!!! I was in the same boat a few months ago, and I really wanted to get a digi approved system. At least with a digi approved system, you could blame someone else if PT didn't run.
In the end, due to budget, I ended up building an i7 rig instead, one that I could I put our 2 PCIX cards in. Spent about $1300 altogether for the new computer, and I couldn't be happier with the performance. Of course, it's not digi approved though.
https://www.thirdeyerecording.com/ |
DTS Lfe specs | Arno Peeters | Post - Surround - Video | 17 | 02-01-2011 09:00 AM |
PT 8 same specs as PT 7? | shultzee13 | Pro Tools M-Powered (Win) | 1 | 04-15-2009 08:32 AM |
Mac specs for PT | A.P. | Tips & Tricks | 3 | 03-24-2009 04:57 AM |
Taking the Plunge and Building a Quad Please Check Specs | Pro Tools LE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-24-2008 12:04 AM |
2gb,check! firewire audio drive,check! samples.... bump!! | MarkusB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-24-2007 02:25 AM |
