#501
Re: The Allenstein Quadzilla Machine *Update 05/20
I suppose you could omit the interface, continue to track with the 002r if you wanted to, and transfer your session to HD for mixing; but you really wouldn't get the full advantage of the HD system in this mode. I'm sure Shan will chime in here with more insight. RP |
#502
There arent many differences between the HD and LE software wise these days. I'm almost certain that will change greatly with the release of 7.2. But the handful of HD only software things can come in handy now and then. A really cool feature is that any RTAS plug-in that clips, will turn red so you will know. That one is VERY cool and handy. Quote:
If you buy it used you can get an HD 1 rig with a 96I/O going for around $5000-$6000. That's a pretty good mid level system if you ask me. I feel it's the mid level system that many of us have been begging for from Digi. If Digi sold this at that price they would probably have alot of HD 1 sales. But that's ok, it all works the same whether it's new or used. There are a few things I should mention though, the lowest H/W buffer you can use in HD is 128, unlike the 64 in LE, which the Quad does very well. This only really effects softsynths and isnt to big of a deal. Also, all your RTAS plug-ins will be bypassed in HD when you hit record.(On the recording track only) To me this is no big deal. I never record with effects on. But if you must do something like this, just use TDM plugs for that purpose. I'm sure as more guys go the hybrid route we can get some of these things changed like the H/W buffer setting etc. Most guys will find that HD 1 and below with a quad(or higher) is more than you'll need for music production. Many of my productions are massive but the HD core and quad can handle it all. I'm up to about 85 tracks on this new production I'm working on. Not a problem. And I can also tell you that if we had true 96 mono tracks in LE, it would still be not a problem on the Quads. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#503
Shane
filosofem
Aaron Mulqueen - 001 HD Native |
#504
How loud is your quad with that silverstone case, and I thought the case only fit ATX mobos? |
#505
How loud is your quad with that silverstone case, and I thought the case only fit ATX mobos? [/QUOTE] If you are going to try and duplicate 3J's results, then I would copy his system to the letter, right down to the same bios version, settings, drivers etc. Shane
#506
Ok everyone, many of the quad users actually communicate via email so not everything gets posted in this thread.
There are two DUC members who are going to build 3J's system to the exact spec. One uses an Mbox and the other uses a 002. So 3J, we even need to go as far as using the same bios, bios tweaks and drivers etc to make sure nothing is different. If we cant duplicate the 3J results with the Mbox and 002, then a few of us will pool our money together to get the same Maudio hardware and send it to the 2 guys with the same system. When we are through with testing we will probably give the Maudio hardware away as a prize on the forum or something. So stay tuned. And 3J, we'll need a hand in a few areas. Shane
#507
Shane
#508
I'm really waiting for this- I've been holding off on the quad for a variety of reasons, but I really want to see if the M-Audio drivers are the root of that incredible performance. Either way, I already have the 002, but I could always get an Audiophile 192 or something for mixing (like the Quad with an 002 wouldn't be enough!! Hahahaha, I'm a moron).
I may just get the mobo with one dual core for now and upgrade when I've got more of a ahem... cash flow.lol I can do that right? You should've seen my students' faces when I brought this up to them... we may have some more Quads on the way...:) you guys rock rocketeer |
#509
I know this is the quad thread, but I thought some here might like to know about the D-Verb test with PTLE 7.1 and PTMP 7.1 on the same machine with the Music Production Toolkit.
I have an 002rack and an Audiophile 192 installed on my computer. AMD Athlon 64 X2 4400+, ASUS A8N-E Mobo, 2 gig ram, SATA system drive, IDE audio drives - It's pretty much the Allenstien machine. I'm not sure I did the D-Verb test per the standard, but I did it the same way with both LE and MP. 5 D-Verbs per track just as they come up on selecting the insert (no adjustments). I used a mono audio track so the D-Verb had something to work on. I duplicated this first track until I ran out of CPU. HW buffer was at 1024, session was 24 bit, 44,100 Hz. I got 75 D-Verbs before I hit the red with both systems. There really didn't seem to be much difference performance-wise. I loaded a fairly heavy PTLE session into MP to compare CPU usage (the session was at 24 bit 48,000 Hz). Both PTLE and MP used about 75% CPU on this session. There was a difference sonically. The AP192 definitely had more high end. When I heard it, my first inclination was to reach for an EQ and start to cut at about 5 kHz and up. This can only be due to the AP192 converters since the AP192 output is routed through the same monitors as the 002rack. I'll have to bounce and burn the session and listen to it an a few other playback systems to see which one seems more accurate. I will try the Null Test within the next few days to see if MP nulls better or worse than LE. Maybe quads are different, but the software seems to perform nearly identically on my system. Thanks, Greg
Protools PC, i9 10990, Gigabyte X299 mobo, 64 GB ram, EVGA Nvidea GT 720 TI video card, Win 10 Pro, PT Ultimate (Native) 2024.3.1, HD Omni, HD I/O 16x16 . |
#510
Okay, I'm so damn close to building a new ProTools workstation I can taste it.
Shan, you mentioned some time ago that you were planning on testing your quad set up with just one Opteron CPU. Have you had a chance to do this yet? I'm looking at either a regular AMD64 X2, or a one CPU Opteron 270 (I'm going to buy through Newegg, but they don't have the 265). I can't afford the whole quad set-up just yet, but will likely be able to get the second CPU and RAM in August/September. I'd really like to see a performance test of the Athlon 64 4400+ X2, vs. one Opteron 270.
Justice C. Bigler www.justicebigler.com Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB 2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre Road/hotel: Roland OctaCaputre / Apogee One |
Intel Core i7 2.0GHz Quad-Core Processor or Intel Core i7 2.7GHz Dual-Core Processor? | okodub | Pro Tools 9 | 3 | 09-23-2011 07:33 AM |
Single core vs. dual core vs. quad core | John Peeples | Tips & Tricks | 9 | 11-07-2007 03:28 PM |
APPLE MAC PRO or The Allenstein "Quadzilla" Machin | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 03-05-2007 11:06 PM |
MAC PRO or The Allenstein "Quadzilla" Machine ???? | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 09-26-2006 11:53 AM |
Opteron 165 Dual-Core, upgrading my Allenstein! | RSSstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-01-2006 08:14 PM |
