Old 10-16-2013, 07:30 AM
K Roche's Avatar
K Roche K Roche is offline
Default Some new key commands not working
So I now have PTHDN 11.0.2 running fine so far Except I was watching the Sweetwater PT 11 demo video on You tube with Rob McGaughey from Avid.
I can use the keyboard shortcuts to create new tracks etc. BUT
@ about 15.13 He talks about bypassing all sends by Holding down "Shift" and "Q" but this does not work, nor does 'Shift ..3 or Shift ...4 also for inserts "Shift...A,,,,, Shift ..E
I have done the PT optimizations as recommended (except for bluetooth for my mouse) And have deselected all non PT key commands
??? Any thoughts on this. Thanks ,Kev
System :
Enjoy the Journey
.... Kev...
Old 10-16-2013, 08:42 AM
Stig Eliassen's Avatar
Default Re: Some new key commands not working
Are you aware that those commands are for selected tracks? Works fine here in 11.0.2.
Old 10-16-2013, 05:18 PM
K Roche's Avatar
Het thanks I'll try that, However in the video @ 15.33 he is in fact Holding down 'Shift and Q to bypass all sends with no tracks selected
Then same with inserts Shift A is supposed to bypass all inserts no tracks selected etc.
Shift E is supposed to bypass all EQs regardless of insert position and again no tracks selected. Great feature but i can't get to work.
Here is the video. check it out... I have it cued at about 15.30
http://youtu.be/Ni1r_pjPY3A?t=15m30s
System :
Enjoy the Journey
.... Kev...
Old 10-16-2013, 05:56 PM
Good point.
I don't know how he made that happen in the video, but it doesn't match the keyboard shortcuts pdf in the documentation for 11. It's been a while since the video was uploaded, so there might've been a change in the 11.0.x updates.
Just speculation on my part, but the only reasonable explanation I can think of.
Old 10-16-2013, 11:58 PM
Shan's Avatar
Shan Shan is offline
The tracks have to be selected first to invoke the command. Given the date of the presentation, he was probably using a beta build and they decided to change the function for final release.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-17-2013, 06:01 AM
K Roche's Avatar
Haden't thought of that makes sense so I guess the good news in that case my system does seem then, to be functioning correctly thanks guys , Kev
System :
Enjoy the Journey
.... Kev...
Some key commands not working in PT 11.1.2 hakofred Pro Tools 11 2 02-05-2014 09:54 AM
Shortcut commands not working E-Lister Windows 4 02-24-2012 11:09 AM
keyboard commands not working. Help! grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-21-2009 01:00 PM
Key Commands not working ? jjamesbomb Pro Tools TDM Systems (Mac) 0 01-25-2009 05:46 PM
"P" and ";" key commands not working 5.2.1LE... tadpole 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-12-2004 11:37 AM
