Re: Is it possible to do this?
Maybe it's coming soon
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4 Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc |
I'm hardly making assumptions about your professionalism. I don't care how long you been in the biz or your credits - that means nothing. What means something is when I give you a legitimate way to take care of things and you automatically dismiss it out of hand. Look at it this way - it's one way to get the job done that works with the current state of PT MIDI.
Thanks -- good to know it's a known issue, will hope for a fix.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
then the above mentioned workaround does work. seeing now that you're coming from a diff daw, i need to mention that by "trim", i'm referring to the trim tool. and if the trax are grouped, they'll all trim at once. as shane says, lame work flow… e
ihatetyping |
#16
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#17
Thanks Shane. In the main Edit window, in Notes View I can't seem to find a way to select an area in the middle of a long sustained MIDI note, within the note as you said. I can do it in the MIDI Editor window, but not in the main Edit window. Maybe I'm wrongly trying to get it to work like Logic, where you can drag across MIDI notes (and audio at the same time), and cut, paste, whatever.
#18
#19
Shane is spot on. It would be great if the MIDI editing paradigm was consistent with audio.
#20
Select the notes you want to trim with selector tool and use the trim tool to lengthen or shorten to the desired length on the grid. Rinse and repeat for other sections. Another way: in note mode, select the part of the clip you want to cut up and hit CTRL E (on Win) and the notes will be split at the selection point. Delete or trim as desired.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
