Old 08-15-2018, 02:33 PM
Raoul23 Raoul23 is offline
Default MIDI issue
My midi keyboard is acting up, for some reason when you record in, the pitch wheel has become faulty and is obviously effecting the plugin in. Is there a way in ProTools for it to ignore the pitch wheel or do I just have to purchase a new keyboard
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 08-15-2018, 02:46 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Midi issue
You have to disable it via the Midi keyboard.. I had to do that with my Axiom. I got rid of it. I wouldn't doubt if that's what you have...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-15-2018, 02:47 PM
Its nocturn one, how would you disable it via the keyboard ???
Raoul Crane
Old 08-15-2018, 02:52 PM
I can't tell you that on that board because I don't have it; look it up though; I'm sure someone has had to do it...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 08-15-2018, 03:03 PM
Ok thank you
Raoul Crane
Old 08-15-2018, 03:35 PM
I definitely hope you get it figured out, because I know 1st hand how much of a pain in the arse that is!!!
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 08-15-2018, 06:54 PM
Pretty sure you can tell PT to ignore pitch bend
Old 08-16-2018, 11:16 AM
Shan's Avatar
Shan Shan is offline
Originally Posted by Raoul23 View Post
...Is there a way in ProTools for it to ignore the pitch wheel...
Setup > MIDI > MIDI Input Filter... > Select Pitch Bend to disable it
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 08-16-2018, 12:52 PM
Default Re: MIDI issue
Well ain't that som'n; I guess it was so easy on the Axiom that I never even thought about going into the obvious input filters! Hahaha
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 08-19-2018, 12:53 PM
Bummer the above solution didn’t work for me.
Raoul Crane
MIDI problem - Midi Studio Issue Microphone33 MIDI 4 02-27-2016 11:49 AM
MIDI problem - Midi Studio Issue Microphone33 Virtual Instruments 0 02-07-2016 02:09 PM
midi issue- can see midi signal but cant's control Xpand2 macroniche Pro Tools 10 1 08-02-2012 12:16 AM
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
Issue When running Midi and more than one Midi Track amayhem MIDI 11 11-05-2009 06:52 PM
