Old 10-11-2005, 12:48 AM
MaLa MaLa is offline
Default Remove unused audio tracks from region list
I had the great idea to let winrip search for all audiofiles. Now I have like 3.000 audio tracks in my playlist and most of it is Pro Tools waste.
I can't find the function to clean the audio lists any more.
Anybody.
Mbox ProTools LE 7.0
Show a little patience! I'm female & blonde
Old 10-11-2005, 01:01 AM
Shan's Avatar
Shan Shan is offline
Default Re: Remove unused audio tracks from region list
Removing Unwanted Regions.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 10-11-2005, 01:47 AM
Thanks a lot Shane.
There is one problem. I have three versions of one song and all the audio files are saved to one folder. So if I remove audio in version 1 it could be missed in version 2. Is there a way that Protools will ask me to save the used audio in a new folder?
Old 10-11-2005, 02:26 AM
Shan's Avatar
First open up one session. Remove(not delete) the unwanted regions as mentioned earlier. Then go to "Save Session Copy" and check the "All Audio Files " box. Rename your session and save it to a different location on your drive. You will now have a nice compact session. Repeat the above for the other two sessions.
'Removing' regions will only just remove the audio from the session. All audio files will still be found in the audio folder.
'Delete' will completely delete the audio files from your drive. If you have any other sessions that are linked to these and you delete them, then your screwed. Big time. Trust me.
My words of wisdom are actually from real first hand experience and dumb mistakes.
Shane
Old 10-11-2005, 02:47 AM
Shane
Ones again perfect advice. Thanks a lot!
8.01 Region List Unused Clearing problem TimNielsen Pro Tools TDM Systems (Mac) 8 09-02-2010 03:39 AM
"Select unused" in Region List also selects "Used" Taliq Pro Tools TDM Systems (Mac) 9 06-16-2008 04:54 AM
Cleaning up audio files (remove unused won't do)? Fastudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2007 03:08 PM
Remove versus Delete when it comes to clearing unused audio... help! tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-26-2002 12:19 AM
Protecting unused regions from being Deleted in Region list BboY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-03-2001 12:35 AM
