Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 01-12-2021, 06:51 AM
bonzerboy bonzerboy is offline
Default Why cant we drop an drag out pots ?
I find myself using busses where i need to group sever track outputs to the bus and have tried all kinds of key combinations when tracks are selected to change all pout puts but nothing seems to work and have to do it one at a time. I think it would be nice to grab like a plug in and do this to outputs.
Wow am I groovy or what
Old 01-12-2021, 07:47 AM
Default Re: Why cant we drop an drag out pots ?
On Mac (not sure of the windows key command), hold opt-shift and select the output. It will change all of the selected tracks. The tracks have to be selected with their names highlighted white, not just have the cursor in the edit window on the track, since track selection and edit selection can be unlinked. I always keep edit and track selection linked so I can drag the selector tool across multiple tracks to select/highlight them.
Scott Gatteño
Old 01-12-2021, 08:16 AM
albee1952 albee1952 is online now
On Windows, selecting the tracks and holding Alt+SHIFT while you mouse-click on one of the track's outputs and change, will do to all selected.
A faster way is to select the tracks and move to a Routing Folder(and check the box to change routing). That will create the folder track(which works just like routing thru an AUX track) and set the routing in a single command(if you are on a recent version of PT).
But, I do agree that dragging across could be very handy, for outputs, solo's, mutes and probably a few other things
Old 01-12-2021, 08:34 AM
Ben Jenssen's Avatar
Alt - action = Apply to all visible tracks.
Alt - shift - action = Apply to all selected tracks.
Works for routing, sends, inserts, solo, mute ++
Old 01-12-2021, 11:36 AM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Here is another handy one:
Shift+option+command+click on a routing selector (Input, Output, Sends) and select a Path (i.e. Bus 5) to assign that Path to that Track and assigns the next Paths in sequential order to all the other selected Track. (i.e. Bus 5, Bus, 6, Bus, 7, etc.).
If even uses a round-robin principle if you didn't click on the first of the selected Tracks.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 01-13-2021, 06:30 AM
daeron80 daeron80 is offline
But beware that routing folder tracks have delay compensation bugs.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 01-13-2021, 06:42 AM
I'm just getting to learn to use routing folders.
Could you outline what the problem with latency compensation is, or point me in the right direction, please?
Old 01-13-2021, 07:13 AM
K Roche's Avatar
K Roche K Roche is online now
Don't know if this is what he means BUT After a search this is the only thing I could find ???
http://duc.avid.com/showthread.php?t=409221
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 01-13-2021, 08:19 AM
That's correct, and the bug has been reported in other forums (gear slutz, pt expert, etc). Routing folders are a nice idea but not a safe option yet.
David J. Finnamore
Old 01-13-2021, 08:44 AM
Thanks.
I suggest we leave it there, as this is turning somewhat off topic to the thread.
I'll revive the thread you linked to, and continue there:
MIDI drag and drop causes instrument track to drop channel midnightrambler Pro Tools 2018 6 06-15-2018 10:01 AM
Trouble drag&drop files - I don't get what I drag in Sir Hannes Post - Surround - Video 3 12-10-2017 07:39 AM
Drag and Drop daslicht Virtual Instruments 0 10-05-2009 10:45 AM
can´t drag /drag and drop from DigiBase in 7 jofromabove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2005 08:04 AM
