Go Back   Avid Pro Audio Community > Announcements > General
Old 10-26-2006, 01:28 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools HD 7.2.1cs1 Update for Mac Pro
Pro Tools HD 7.2.1cs1 for Apple Mac Pro is available for download from the HD 7.2.1 downloads and Pro Tools CS Updates page:
http://www.digidesign.com/index.cfm?...4&itemid=23895
The Pro Tools CS Updates page is a Quick Link in the Support section:
www.digidesign.com/support
Pro Tools HD 7.2.1cs1 for Mac OS X contains the following:
Fixed: Unintentional Timeline Selections Could Be Made While Editing (Item #76606)
- This could occur when immediately moving the mouse/trackball after unclicking.
Fixed: "Auto-Write On Stop" Modes Could Improperly Overwrite Data (Item #82271)
- "Auto-Write On Stop" mode (to start, to all/selection, to end) would affect any automation write, even if it had been automatched out.
Fixed: Original Timestamps of Imported Avid .WAV Files Would Be Reset Upon a Subsequent Session Opening (Item #81997)
- This bug would not occur if the audio had valid soundroll timestamps in the Avid source bin.
- This bug would prevent the automatic matching features of field recorder workflows in Pro Tools.
Fixed: Updating HD Interface Firmware With DigiTest on Intel-based Mac OS X Leaves the Interface Unrecognizable (Item #82896)
- A data verification error is returned, and Pro Tools will no longer recognize the interface when launching Pro Tools.
Fixed: Embedded OMF Sequences Can Play Back Incorrectly (Item #82926)
- When the OMF file had been set to "Read only" on Windows or "locked" on Mac, every region played the same audio data.
- Attempting to re-import the OMF after the session was opened resulted in a message, "Some regions were truncated or removed from the region list or timeline because they referred to files which are too short."
This update is recommended for all Pro Tools HD 7.2.1 for Intel-based Mac users and contains fixes in the following areas:
  • Editing
  • Automation
  • Field Recorder workflows
  • DigiTest
  • Importing embedded OMF sequences
Administrator
HTML code is On
Pro Tools 8.0.1cs1 update. MultiCore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-12-2009 04:22 PM
Pro Tools HD 7.2.1cs1 Update for Mac Pro Avid Pro Tools TDM Systems (Mac) 0 10-26-2006 01:29 PM
Pro Tools TDM 6.9.1cs1 Update Avid Pro Tools TDM Systems (Win) 0 07-13-2005 03:49 PM
Pro Tools TDM 6.9.1cs1 Update Avid Pro Tools TDM Systems (Mac) 0 07-13-2005 03:47 PM
Pro Tools LE 6.0.1cs1 Update for Digi 001 Avid General 0 05-08-2003 08:33 PM
