MBox 3 - Lights Blinking in Sequence
Hello! I'm struggling with getting my MBox 3 (not mini and not pro) installed. I've tried many of the items listed here and have had no luck.
The MBox 3 looks like it is going to turn on when it lights up. Then it waits for a second, then the lights go through a sequence blinking and following the same path. Then, it starts over. This sequence of lights continues forever. I'm running XP SP3. I've installed and uninstalled all available drivers multiple times. I've tried other computers but all are giving me the same issues. I've tried setting the power settings in the USB ports and uninstalling them and reinstalling those (then going back and making sure Windows doesn't power down those ports). I've done all of the XP optimization options listed on the Avid site. When I connect the unit to the computer, Windows never finds it. I've tried forcing Windows to install the drivers, but that didn't work. Am I missing something here? I've tried finding what the sequence of lights means throughout this board and throughout the internet but can't find what that means. I've seen multiple people fix their similar issues, but all of those didn't help me. I have a Dell Optiflex 760 which isn't a great machine, but it runs XP really fast. But, like I said, I tried this in multiple computers and had the same issue. Any help? Sorry if I missing something obvious! |
Re: MBox 3 - Lights Blinking in Sequence
What version of PT? Also, I'd advise you post us a Sandra Report so we can have a more detailed look at your system. Here is a good resource to start with:
http://duc.avid.com/showthread.php?t=300050 ...and welcome to the forum! Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Sorry - I'm looking to run Pro Tools 8 LE 8.0.4.
Here is the Sandra report: SiSoftware Sandra ID Host Name : 921DCCLT-7 Workgroup : MSHOME Computer Model : Dell OptiPlex 760 Serial Number : 864**** Chassis : Dell Space-saving Mainboard : Dell 0M863N Serial Number : ..CN7360********* BIOS : Dell A03 04/29/2009 Intel vPro : 5.01.00.1167 Total Memory : 3GB DIMM DDR2 Processors Processor : Pentium(R) Dual-Core CPU E5200 @ 2.50GHz (2C 2.5GHz, 2MB L2) Socket/Slot : FC LGA775 Chipset Memory Controller : Dell Q45/Q43 DRAM Controller 4x 200MHz (800MHz), 2x 3GB DIMM DDR2 800MHz 128-bit Memory Module(s) Memory Module : Nanya NT2GT64U8HD0BY-AD 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Micron 16HTF25664AZ-1GAH1 2GB DIMM DDR2 PC2-8900U DDR2-1112 (5-7-7-25 4-32-8-4) Memory Module : Micron 16HTF25664AZ-1GAH1 2GB DIMM DDR2 PC2-8900U DDR2-1112 (5-7-7-25 4-32-8-4) Video System Monitor/Panel : (Standard monitor types) Default Monitor Video Adapter : \\.\DISPLAY1 Graphics Processor Storage Devices WDC WD800AAJS-75M0A0 (80GB, SATA300, 3.5", 7200rpm, 8MB Cache) : 75GB (C:) TSSTcorp DVD+/-RW TS-L633C (384.7MB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 367MB (D:) Logical Storage Devices Hard Disk (C:) : 74GB (NTFS) @ WDC WD800AAJS-75M0A0 (80GB, SATA300, 3.5", 7200rpm, 8MB Cache) Pro Tools LE (D:) : 366MB (CDFS) @ TSSTcorp DVD+/-RW TS-L633C (384.7MB, SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell LPC Interface Controller LPC Legacy Controller 1 : T1 8D-01 Audio Device : Dell HD Audio Controller Serial Port(s) : 2 Parallel Port(s) : 1 Disk Controller : Dell Q45/Q43 PT IDER Controller Disk Controller : Dell 4 port SATA IDE Controller Disk Controller : Dell 2 port SATA IDE Controller USB Controller 1 : Dell USB UHCI Controller #4 USB Controller 2 : Dell USB UHCI Controller #5 USB Controller 3 : Dell USB UHCI Controller #6 USB Controller 4 : Dell USB EHCI Controller #2 USB Controller 5 : Dell USB UHCI Controller #1 USB Controller 6 : Dell USB UHCI Controller #2 USB Controller 7 : Dell USB UHCI Controller #3 USB Controller 8 : Dell USB EHCI Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Win2PDF (1440x1440, Colour) Printer : Win2PDF (1440x1440, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Microsoft Office Live Meeting 2007 Document Writer Driver (200x200) Printer : HP Photosmart 7800 Series (1200x1200, USB, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Network Services Network Adapter : Intel(R) 82567LM-3 Gigabit Network Connection - Packet Scheduler Miniport (Ethernet, 1Gbps) Operating System Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 |
I had this issue after connecting two mics using phantom power without switching it off first.
Resolved by connecting the mbox to a different computer (without any drivers installed), in this case one running windows (I'm on a Mac). So, if you can find another computer to hook it up to, try that. |
I tried running this from my friend's computer (Mac) with the exact same Mbox and it did the same sequence of lights. We used the same USB that is hooked up to his computer. Then, when we connected his back up again, his booted up correctly.
But you mentioned connecting it to a computer that doesn't have the drivers installed. I tried connecting this to an XP SP3 machine, Vista (64-bit though...), Windows 7 (32-bit), and now a Mac. Same issue. I've read about the powered USB hubs solving this for some people, but I've also read that I shouldn't connect this to hubs. Another friend mentioned a Vegas mode or diagnostic mode on his digi003 to flash all of the lights as a test. But, is there anything like this with the Mbox 3? I'm going to try to call Avid tomorrow and see what they can help with. |
C:\Program Files (x86)\Avid\Pro Tools\Pro Tools Utilities\DigiTest You'll find it in a similar file path in PT 8. I'm uncertain if DigiTest can be run on the Mbox 3 though. Shane
AFAIK digitest is for tdm hardware and not for the mbox. Don't know about hdx hardware though.
Hi
I am looking at the RAM it says 3 GB but you have 6GB un-matched RAM installled so that has to be looked at either way. Chris
Did you ever find a solution to the problem? I'm experiencing the same thing.
It also appears he's using on-board graphics, and recording to his system drive. And, with audio interfaces, he needs to always connect them with the computer off, then turn the computer on. But before that, he's probably going to need to uninstall Pro Tools and remove everything that is in any way connected to Pro Tools.Then, IIRC, in this instance, he should start his computer with the MBox not connected, then plug it in when the installation program tells hiim to do so. Chris...if you don't mind, please double-check what I posted...I think it's okay, but since I'm working from memory, which ain't what it used to be, it would be good to have a second pair of eyes looking at it!
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
MBox 3 Problem Blinking Lights | alvinspeaks | FireWire & USB Audio Interfaces (Mac) | 0 | 03-01-2014 02:46 PM |
MBOX 3 blinking lights - Phantom Power?? | groversi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-20-2014 02:12 PM |
Mbox 3g Flashing lights sequence osx 10.7.5 | beatsamillion | FireWire & USB Audio Interfaces (Mac) | 3 | 04-25-2013 05:52 AM |
D-Control Trim Lights Blinking | JKD99 | ICON & C|24 | 6 | 04-22-2010 08:32 AM |
C24 Blinking lights and clicking... help! | Nicolasixxx | ICON & C|24 | 10 | 08-10-2006 11:50 AM |
