Old 02-10-2012, 08:42 AM
vudoo vudoo is offline
Default can Omni be used with other apps
Can i use the new digi interface, like Omni, with other apps ( Ableton live, Logic..etc). I want my apps to speak directly with the interface and the abilitiy to set low buffer....no rewire crap. Thanks
Old 02-10-2012, 09:18 AM
Diccer Diccer is offline
Arrow Re: can Omni be used with other apps
You could assign Logic or Ableton, but then you couldn't run Pro Tools simultaneously. There are no virtual audio buses to port as there is no vmixer, and Digidesign audio devices are a 1 Master application kindof interface.
If you want to set the buffers, have midi out, ability to use plug ins etc on multiple apps then running Parallel is the way to go. But that would require a different interface such as Focusrite's MixControl, Apogee's Vbus or RME.
Just Run Pro Tools as a Rewire Slave/Run Parallel.. its easier than you think. Example- RME TotalMix and the IAC Midi Driver
http://duc.avid.com/showthread.php?t=313749
Old 02-10-2012, 05:56 PM
Default Re: can Omni be used with other apps
Yes. Using core audio (on Mac) or ASIO (on pc) you can use any audio application outputting through your Omni (or any other Avid I/O box).
Jack
QAPLA!
Old 02-10-2012, 06:34 PM
Have you tried it ??? can i set the buffer as low as 32 or 64 using asio with omni ??? Thanks
Old 12-13-2012, 06:05 AM
Thunderbay Thunderbay is offline
I'm using Ableton Live with my Omni and HDX for programming.
My problem is that I can't change buffer size from 64 samples.
And it makes LIVE crack up when I push it.
Anyone else got experience with this?
Best,
Fredrik
Omni vs HD 8x8x8 io and Omni Pre's Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 13 03-27-2013 01:00 AM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
Anyone using C8 with apps other than PT? silverlode ProControl, Control|24, Command|8 4 09-05-2004 11:05 AM
PT6 & other apps C Craig 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-10-2003 12:46 AM
